製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
Note
If you want to use SSDs with reComputer, we only recommend you choose the 128GB, the 256GB, and the 512GB versions from Seeed, because some of the SSDs in the market will work with this product under a particular JetPack version and some will not work with a different JetPack version. Even the official NVIDIA dev kits have the same behavior with SSDs.
仕様
Jetson Orin NX System on Module
AI Performance
reComputer Industrial J4012 - Orin NX 16GB, 100 TOPS
reComputer Industrial J4011- Orin NX 8GB, 70 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU (Orin NX 16GB)
6-core Arm® Cortex®-A78AE (Orin NX 8GB)
Memory
8GB 128-bit LPDDR5 (Orin NX 8GB)
Video Decode
1x 8K30 (H.265) 2x 4K60 (H.265) 4x 4K30 (H.265) 9x 1080p60 (H.265) 18x 1080p30 (H.265)
Video Encode
1x 4K60 (H.265) 3x 4K30 (H.265) 6x 1080p60 (H.265) 12x 1080p30 (H.265)
DL Accelerator
2x NVDLA v2
Carrier Board
Storage
1x M.2 Key M PCIe Gen4.0 SSD (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x LAN1 RJ45 GbE PoE(PSE 802.3 af 15 W)
1x LAN2 RJ45 GbE (10/100/1000Mbps)
Wi-Fi
Support SMD Wi-Fi/Bluetooth (Customized production, please contact [email protected])
M.2 Key B
1x M.2 Key B support 4G/5G (Module optional)
I/O
USB
3x USB3.2 Gen1, 1x USB2.0 Type C(Device mode), 1x USB2.0 Type C For Debug UART & RP2040
DI/DO
4x DI,4x DO, 3x GND_DI, 2x GND_DO, 1x GND_ISO,1x CAN
COM
1x DB9 (RS232/RS422/RS485)
Display
1x HDMI 2.0 Type A
SIM
1x Nano SIM card slot
Fan
Fanless, passive heatsink; 1x Fan connectors(5V PWM)
TPM
1x TPM 2.0 connector (Module optional)
RTC
1x RTC socket, 1x RTC 2-pin
Camera
2x CSI (2-lane 15pin)
Power
Power Supply
DC 12V-24V Terminal block 2 pin
Power Adapter
19V Power Adapter(without power cord)
Mechanical
Dimensions (W x D x H)
159mm x 155mm x 57mm
Weight
1.57kg
Installation
Desk, DIN rail, wall-mounting, VESA
Environment
Operating Temperature
-20 ~ 60°C with 0.7m/s airflow
Operating Humidity
95% @ 40 °C (non-condensing)
Vibration
3 Grms @ 5 ~ 500 Hz, random, 1 hr/axis
Shock
50G peak acceleration (11 msec)
Warranty
2 Years
IP Rating
IP40
ハードウェア概要
Full System
Carrier Board
Desktop, Wall Mount, DIN Rail, VESA mount to fit in anywhere
You can either place the device on a desk, mount the device on a VESA mount or mount it on a wall with the back screw holes. You can also place the device on a DIN Rail with the included brackets.
用途
The reComputer industrial series is a versatile and powerful platform that can be used to develop a wide range of AI-powered applications, enabling digital transformation across industries. Below are some of the applications it is suitable for:
  • AI Video Analytics
  • Machine Vision
  • Medical Imaging
  • Autonomous Mobile Robot (AMR)
  • Generative AI
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer Industrial J4011 (System Installed)
x1
x1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reComputer Industrial J4011- Fanless Edge AI Device with Jetson Orin™ NX 8GB module
SKU 110110190
reComputer Industrial J4011 features NVIDIA Jetson Orin™ NX module for 70 TOPS AI performance and supports hybrid connectivities, fanless with versatile mounting options allowing deployment for more harsh environments and heavier loads.
Processor
Memory
JPY¥205598.00
