製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Fast serial communication with CAN Bus rate up to 1Mb/s
  • Easy Setup with all components included
  • Easily get started with the provided Arduino-based tutorials
  • Multi-platform support (Arduino, Raspberry, Beaglebone Board, etc.)
What is OBD-II?
OBD-II (short for On-Board Diagnostics, Second Generation) is a set of standards for implementing a computer-based system to control emissions from vehicles. Also, it can be explained as a vehicle’s built-in self-diagnostic system. When your vehicle has an internal issue, it would normally pop up a malfunction indicator light on your dashboard, telling you to visit a mechanic and get the issue fixed. In the past, this light would just indicate, but it was not possible to identify what the issue was. But nowadays, the OBD-II built inside vehicles, allows you to identify the exact problem of the vehicle by connecting an OBD-II reader to the OBD-II 16-pin connector built inside the vehicle. Through this, it's possible to read OBD-II codes which are also known as Diagnostic Trouble Codes (DTCs) which are helpful in understanding the issues, without needing to completely disassemble the vehicle.
OBD-II was first introduced in the United States in 1994 and became a requirement for all 1996 and newer US vehicles. Other countries, including Canada, parts of the European Union, Japan, Australia, and Brazil adopted similar legislation. A large portion of the modern vehicle fleet supports OBD-II or one of its regional flavors.
How This Kit Can be Used for OBD-II?
This kit is the perfect solution for you to communicate with your vehicle's OBD-II interface without visiting a mechanic. It includes a Serial CAN Bus module, an OBD-II Connector, and other accessories to help you do all the diagnostics and data logging with ease. We also provide a tutorial which is based on Arduino and you can easily obtain data from your vehicle by following this tutorial.
What are OBD-II PIDs?
OBD-II PIDs(Parameter IDs) are a set of codes that are used to request data from a vehicle. Through OBD-II PIDs, you can obtain vehicle data such as speed, throttle position, and RPM of the engines.
Please click here to explore a list of standardized OBD-II PIDs for your reference.
Note
This kit doesn't include a controller board.
Tip
To learn more about CAN Bus, don’t forget to check our blog Introduction to CAN BUS and How to use it with Arduino
Tip
To explore more CAN BUS related products, explore the following:
Hardware Overview of Serial CAN Bus Module
14-pin 2.0mm Grove Connector
2Power and status LED indicator
3Send and receive LED indicator
43.5mm terminal to connect to CAN Bus (CAN_H & CAN_L)
5120Ω resistor, default connected (if you don't need this, you can cut this pad with a box cutter)
Pinout Diagram of OBD-II connector
1Vendor Option9Vendor Option
2J1850 Bus +10J1850 Bus
3Vendor Option11Vendor Option
4Chassis Ground12Vendor Option
5Signal Ground13Vendor Option
6CAN (J-2234) High14CAN (J-2234) Low
7ISO 9141-2 K-Line15ISO 9141-2 Low
8Vendor Option16Battery Power
Connection Diagram
The kit includes a cable as well, you need a soldering iron to connect the cable to the connector. As shown below.
Tip
Please check “Documents” section to get started with this development kit.
Parts List
  • 1 x Serial CAN Bus Module
  • 1 x OBD-II Connector
  • 1 x Screwdriver
  • 1 x Cable for CAN Bus
  • 1 x Grove Cable
認証
HSCODE9030899090
USHSCODE9030890100
UPC841454122111
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions110mm x83mm x43mm
WeightG.W 71.5g
BatteryExclude
OBD-II CAN-BUS Development Kit
SKU 114991438
JPY¥3039.00
¥3799.00
Save ¥760.00(20%)
