おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Powerful Raspberry Pi RP2040 processor
  • Implements CAN V2.0B at up to 1 Mb/s
  • Industrial standard 9 pin sub-D connector or 4PIN Terminal.
  • OBD-II and CAN standard pinout selectable at the sub-D connector
  • 2x4Pin Connector compatible with Grove system from Seeedstudio
  • SPI Interface
  • Standard (11 bit) and extended (29 bit) data and remote frames
  • Power input from 9-28V
The CANBed RP2040 version has been changed from V1.0 into V1.1. For further information, please check here.
CANBed RP2040 is a CAN Bus development board equipped with an RP2040 chip with a high-performance MCP2515 CAN controller and MCP2551 CAN receiver operating at CAN2.0 protocols in 133MHz. The board contains a flexible CAN interface where it can be used 4-PIN Terminal or D89 connector. D89 connector can be directly used as OBD-II mode by default and the hardware can be configured as CAN Open mode as well. Additionally, it has a rich interface in which there is a Micro USB connector that can be programmed instead of supplying power. It also has I2C, UART, SPI, 3 analog input interfaces, and 8 digital IO with 2MB of Flash and 264KB of RAM which make it suitable for most embedded applications.
If you want to use this board to develop OBD-related applications, click to get a DB9 to OBD-II cable.
We use a flexible way for the CAN interface. You can use 4PIN Terminal or DB9 connector. DB9 connector uses OBD-II mode by default. You can also configure CAN Open mode on the hardware. The voltage input range of the CAN interface is 9-28V, which can provide a stable 3.3V/1A output.
ParameterValue
MCURP2040
Clock Speedflexible clock running up to 133 MHz
Flash Memory2MB
RAM264KB
Operate Voltage9-28V
Output Current @ 3.3V1A
Input Interfacesub-D
Application
  • Hack and Upgrade Your Car
  • Vehicle dynamics control system
  • Attitude and orbit control system
Hardware Pinout
1. GPIO - 9x2 I/O Pin OUT:
2. Micro USB connector for programming
3. SPI Interface
4. CAN RX/TX Indicator
5. DB9 connector or Terminal for CAN Bus
6. Switch for the 120Ω terminal resistor for CAN Bus
7. Grove connector for UART
8. Grove connector for I2C (Wire1)
9. Reset
CAN Bus Family in Seeed
CAN-BUS series product selection reference is provided here. The table compares NEW-Release Wio-E5 CAN, CANBed v1, CANBed FD, CANBed M4, and CANBed RP2040 in terms of MCU, protocol, memory, interface, etc.
Items
Wio-E5 CAN
CANBed v1
CANBed FD
CANBed M4
CANBed RP2040
CANBed Dual
MCU
Wio-E5 (STM32WLE5JC)
ATmega32U4(with Arduino Leonardo bootloader)
ATmega 32U4 (with Arduino Leonardo bootloader)
ATSAME51 32bit Cortex M4 core
RP2040
(Dual ARM Cortex-M0+)
RP2040
Clock Speed
up to 48MHz
16MHz
16MHz
120MHz
up to 133 MHz
133MHz
Protocol
Long Range,RS485,CANFD & CAN2.0
CAN2.0
CANFD & CAN2.0
CANFD & CAN2.0
CAN2.0
CANFD & CAN2.0
Flash Memory
256KB
32KB
32KB
512KB
2MB
2MB
SRAM
64KB
2.5KB
2.5KB
192KB
264KB
264KB
EEPROM
1KB
1KB
Operate Voltage(CAN-BUS)
4.5~28V
9-28V
7-28V
7~28V
9-28V
9-28V
Operate Voltage (MicroUSB)
5V
5V
5V
5V
3.3V
5V
Lipo Battery
3.7V
Input Interface
9 pin sub-D or 4PIN Terminal
sub-D as well as Terminal
sub-D
Sub-D
Price
$39.90
$24.90
$17.90
$19.90
$15.90
$14.9
CANBed 2040 PCBAx1
Sub-D connectorx1
4PIN Terminalx1
4PIN HY2.0 Connectorx2
9x2 2.54 Headerx1
3x3 2.54 Headerx1
Switch for 120Ω terminal resistorx1
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
CANBed - Arduino CAN-Bus RP2040 development board
SKU 102991596
CANBed CAN Bus development board equipped powerful RP2040 has high-performance CAN controller and receiver operating at CAN 2.0 up to 133Mhz. It has flexible CAN interface which can be used as 4-PIN Terminal or D89 connector as OBD-II mode through a programmable Micro USB.
USD$18.90
product.detail.alsoAdd.title
