おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Cart to CAN-BUS communication
  • Support AT command
  • Up to 115200 UART baud rate (default 9600)
  • Up to 1Mb/s CAN-BUS baud rate
  • TX and RX led indicator
  • 4pin Grove connector to plug and play
  • 3.3V working voltage
  • Easy-to-use Arduino library
MCP2551 and MCP2515 Serial CAN-BUS Module enable your Arduino and other MCU to communicate to CAN-BUS to hack your vehicle. CAN-BUS is a common industrial bus because of its long travel distance, medium communication speed, and high reliability. This Serial CAN-BUS module is based on MCP2551 and MCP2515, which provides speed up to 1Mb/s. It also has a terminal block so you can connect to your vehicle’s OBD-II port with two wires.
There's Grove connect as well as Grove cable included in the kit, which allows connecting the module to your Arduino easily.
Size and Hardware Overview
  • 4 pin 2.0mm Grove Connector
  • Power and status led indicator
  • Send and Recv led indicator
  • 3.5mm terminal to connect to CAN-Bus (CAN_H & CAN_L)
  • 120Ω resistor, default connected, if you don't need you cut this pad with a box cutter.
We also recommend  OBD-II CAN-BUS Development Kit, which is consists of the Serial CAN Bus module as well as the OBD-II connector.
Note:
As the module uses serial communication, so the frequency of receiving data can't be too fast, you can receive a frame every millisecond under 115200 baud rate.
Support
Please feel free to contact [email protected] if you need tech support.
認証
HSCODE8543909000
USHSCODE8543903500
UPC841454121336
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions20mm x40mm x10mm
WeightG.W 9.5g
BatteryExclude
部品リスト
Serial CAN-Bus PCBA1
4 Pin Grove cable1
Small screwdriver1
Serial CAN-BUS Module based on MCP2551 and MCP2515
SKU 114991377
MCP2551 and MCP2515 Serial CAN-BUS Module enable your Arduino and other MCU to communicate to CAN-BUS to hack your vehicle. This module provides speed up to 1Mb/s. It also has a terminal block so you can connect to your vehicle’s OBD-II port with two wires.
USD$22.00
product.detail.alsoAdd.title
