おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Supports CAN-FD and CAN2.0
  • Powerful ATSAME51G19A 32bit Cortex M4 core
  • Industrial standard 9-pin sub-D connector or a 4-pin terminal connector
  • OBD-II and CAN standard pinout selectable at the sub-D connector
  • 2x4-pin connector compatible with Grove ecosystem
CAN Bus is a common industrial bus because of its long travel distance, medium communication speed, and high reliability. It is commonly found on modern machine tools, such as an automotive diagnostic bus.
This CANBed M4 is the latest board of the CANBed family, with the ATSAME51G19A MCU and MCP2542FD CAN transceiver to achieve the CAN-FD capability.
What is CAN-BUS?
CAN stands for Controller Area Network, it is used to allow microcontrollers and devices to communicate with each other within a vehicle without a host computer which allows for control and data acquisition. These devices are also called Electronic Control Units (ECU) and they enable communication between all parts of a vehicle.
Today, you can find up to 70 ECUs in a modern car. CAN is a serial communication bus designed for industrial and automotive applications. For example, they are found in vehicles, farming equipment, industrial environments, etc.
How does CAN-BUS work?
The fuel level, door sensors, odometer, and many more parts of a car have to communicate with each other somehow, and CAN BUS is what they used to do. These CAN-compatible components, which are called “nodes” are connected with a 3-string copper wire, with no central router to govern the flow of data. Every node can hear the messages of every other node.
Every node has an ID, where the ones with the higher priority ID can have the priority to “talk” first while the others “listen”. This is to ensure that there are never two nodes talking at the same time. The biggest benefit of CAN-BUS is to be able to just connect components without having to worry about signal routing.
Learn more about CAN-BUS here.
Application
  • Car Hacking: easily connect the circuit board to the OBD interface, get the data such as temperature, position, stability of your vehicle
  • Easy building prototype: Powerful ATSAME51G19A 32bit Cortex M4 core helps build various prototypes.
MCU
ATSAME51 32bit Cortex M4 core
Clock speed
120MHz
Flash memory
512KB
RAM
192KB
EEPROM
No EEPROM
Input voltage
7~28V
Input interface
Sub-D as well as Terminal
Size
56x41mm
Hardware Overview
1.9x2 IO Pin OUT
2.ATSAME51G19A
2. Reset Button
3. Micro USB connector for programming
4. SPI Interface
5. CAN RX/TX Indicator
6. sub-D connector or Terminal for CAN Bus
7. Switch for the 120Ω terminal resistor for CAN Bus
8. Grove connector for UART
9. Grove connector for I2C
CAN Bus Family in Seeed
CAN-BUS series product selection reference is provided here. The table compares NEW-Release LoRa-E5 CAN, CANBed v1, CANBed FD, CANBed M4, and CANBed RP2040 in terms of MCU, protocol, memory, and interface, etc.
Items
Wio-E5 CAN
CANBed v1
CANBed FD
CANBed M4
CANBed RP2040
CANBed Dual
MCU
Wio-E5 (STM32WLE5JC)
ATmega32U4(with Arduino Leonardo bootloader)
ATmega 32U4 (with Arduino Leonardo bootloader)
RP2040
(Dual ARM Cortex-M0+)
RP2040
Clock Speed
up to 48MHz
16MHz
16MHz
120MHz
up to 133 MHz
133MHz
Protocol
Long Range,RS485,CANFD & CAN2.0
CAN2.0
CANFD & CAN2.0
CANFD & CAN2.0
CAN2.0
CANFD & CAN2.0
Flash Memory
256KB
32KB
32KB
512KB
2MB
2MB
SRAM
64KB
2.5KB
2.5KB
192KB
264KB
264KB
EEPROM
1KB
1KB
Operate Voltage(CAN-BUS)
4.5~28V
9-28V
7-28V
7~28V
9-28V
9-28V
Operate Voltage (MicroUSB)
5V
5V
5V
5V
3.3V
5V
Lipo Battery
3.7V
Input Interface
9 pin sub-D or 4PIN Terminal
sub-D as well as Terminal
sub-D
Sub-D
Price
$39.90
$24.90
$17.90
$19.90
$15.90
$14.9
CANBed M4 PCBA
1
Sub-D Connector
1
4PIN Terminal
1
4PIN 2.0 Connector
2
9x2 2.54 Header
1
2x3 2.54 Header
1
ドキュメント
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
CANBed M4 Development Board with ATSAME51G19A MCU and MCP2542FD CAN Transceiver
SKU 102991495
USD$19.90
廃番
product.detail.alsoAdd.title
