おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Pocket size and light weight
  • Solid aluminum metal case
  • Includes a transport EVA carry case for RF Explorer
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
  • High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
  • Windows PC client Open Source
  • Can be extended with internal Expansion Modules for additional band and functionality
  • Wide band coverage to all popular RF frequencies, starting at 15MHz and going up to 2.7GHz. This include very interesting frequency areas such as 2m HAM radio, all VHF and UHF, FM radio, GPS, WiFi and WiMax, Bluetooth, etc.
Note
This unit does not include RF Generator functionality, only Spectrum Analyzer functionality is available.
RF Explorer is a handheld digital spectrum analyzer, a very affordable tool for work in all popular frequency bands. It is based on a highly integrated frequency synthesizer and double balanced mixer which offers high performance, compact size, low consumption and low cost.
It has been designed to be used equally well outdoor and indoor, and can be connected to a PC for extra functionality using standard mini-USB 2.0 connector.
This model includes a WSUB1G baseline unit plus an RFEMWSUB3G Expansion Module conveniently assembled and tested. It comes with two SMA connectors and two antennas,a nice dual band telescopic 144/430MHz wideband telescopic antenna for all Sub-GHz frequencies and a whip helical for 2.4GHz band. Additional, specific band antennas may be needed to cover efficiently some of the frequencies supported.
The combination of these two models offer the wide band coverage of the WSUB3G module, together with the highest sensitivity and quick response of the WSUB1G model for the popular sub-1GHz frequencies.
Tech support
This product is designed by RF-Explorer
  • For more info and to get started with your RF Explorer, visit the start page.
  • For questions and support, please visit https://support.rf-explorer.com
  • For the software for RF Explorer series, please click the following logo for more information:
Compliance
All RF Explorer models are complaint with FCC as well as CE regulations.
All RF Explorer Wideband models have been certified under EN/IEC61236 and EN/IEC61000.
All RF Explorer models are RoHS compliant
認証
HSCODE9030401000
USHSCODE9030400000
UPC841454104018
EUHSCODE9030900000
COOCHINA
技術詳細
Dimensions0mm x0mm x0mm
WeightG.W 372g
BatteryLithium Cells / Batteries contained in equipment UN3481 - PI967
Frequency band15-2700 MHz
Frequency span112KHz - 600MHz
Graphics LCD128x64 pixels, great visibility outdoors
PC Windows clientsupports Windows XP/Vista/Win7 both 32 and 64bits
Backlightfor great indoor visibility
2 standard SMA 50 ohms connector,one for Sub-GHz wideband Nagoya NA-773 telescopic antenna included and another 2.4Ghzone for 15-2700 MHz band with helical antenna included.
Amplitude resolution0.5dBm
Dynamic range
Left SMA port (WSUB1G)-115dBm to 0dBm
Right SMA port (WSUB3G)-110dBm to -10dBm
Absolute Max input power
Left SMA port (WSUB1G)+5dBm
Right SMA port (WSUB3G)+30dBm
Average noise level (typical)-110dBm
Frequency stability and accuracy (typical)+-10ppm
Amplitude stability and accuracy (typical)+-6dBm
Frequency resolution1Khz
Resolution bandwidth (RBW)automatic 3Khz to 600Khz
Weight185g
Size113x70x25 mm
部品リスト
RF Explorer 3G Combo1
Nagoya NA-773 wideband telescopic antenna1
2.4GHz band antenna1
EVA Case1
RF Explorer 3G Combo Spectrum Analyzers
SKU 109990009
USD$289.00
product.detail.alsoAdd.title
