おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Pocket size and light weight
  • Solid aluminum metal case
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
  • Lifetime free firmware upgrades available, open to community requested features
  • High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
  • Windows PC client Open Source
  • Can be extended with internal Expansion Modules for additional band and functionality
  • Wide band coverage to all popular sub-1Ghz ISM bands, including 315MHz, 433MHz, 868MHzand • 915MHz, also including UHF TV, 70cm and 33cm HAM radio, GSM, etc. Any frequency from 240MHz to 960MHz is covered.
Note
This unit does not include RF Generator functionality, only Spectrum Analyzer functionality is available.
RF Explorer is a handheld digital spectrum analyzer, a very affordable tool for work in all ISM popular frequency bands. It is based on a highly integrated frequency synthesizer which offers high performance, compact size, low consumption and low cost.
It has been designed to be used equally well outdoor and indoor, and can be connected to a PC for extra functionality using standard mini-USB 2.0 connector.
This model comes with a nice dual band telescopic 144/430MHz wideband telescopic antenna.
Tech Support
  • For more info and to get started with your RF Explorer, visit the start page.
  • For questions and support, please visit https://support.rf-explorer.com.
  • For the software for RF Explorer series, please click the following logo for more information:
Compliance
All RF Explorer models are complaint with FCC as well as CE regulations.
All RF Explorer Wideband models have been certified under EN/IEC61236 and EN/IEC61000.
All RF Explorer models are RoHS compliant
認証
HSCODE9030401000
USHSCODE9030400000
UPC841454103912
EUHSCODE9030900000
COOCHINA
技術詳細
Dimensions0mm x0mm x0mm
WeightG.W 284g
BatteryLithium Cells / Batteries contained in equipment UN3481 - PI967
Frequency band240 - 960 MHz
Frequency span112KHz - 100MHz
Amplitude resolution0.5dBm
Dynamic range-115dBm to 0dBm
Absolute Max input power+5dBm
Average noise level (typical)-110dBm
Frequency stability and accuracy (typical)+-10ppm
Amplitude stability and accuracy (typical)+-3dBm
Frequency resolution1Khz
Resolution bandwidth (RBW)automatic 2.6Khz to 600Khz
Weight185g
Size113x70x25 mm
部品リスト
RF Explorer model WSUB1G1
Nagoya NA-773 wideband telescopic antenna1
RF Explorer WSUB1G Spectrum Analyzers
SKU 109990010
RF Explorer is a handheld digital spectrum analyzer, a very affordable tool for work in all ISM popular frequency bands.This product is a co-create collaboration with Seeed Studio and RF Explorer.
USD$149.00
product.detail.alsoAdd.title
