おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
RF Explorer is a handheld digital spectrum analyzer, aimed to provide a very affordable tool for work in all ISM popular frequency bands. It is based on a highly integrated frequency synthesizer which offers high performance, compact size, low consumption and low cost.
It has been designed to be used outdoor and indoor, and works nice with a PC connected for extra functionality using standard mini-USB 2.0 connector.
Feature
  • Pocket size and light weight
  • Solid aluminum metal case
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
  • Integrated RF Signal Generator
  • Lifetime free firmware upgrades available, open to community requested features
  • High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
  • Windows PC client Open Source
  • Can be extended with internal Expansion Modules for additional band and functionality
  • Frequency band: 2400-2485 MHz
  • Frequency span: 2-85 Mhz
  • Graphics LCD 128x64 pixels, great visibility outdoors
  • PC Windows client supports Windows XP/Vista/Win7 both 32 and 64bits
  • Backlight for great indoor visibility
  • Standard SMA 50 ohms connector, a matching antenna is included
  • Amplitude resolution: 0.5dBm
  • Dynamic range: -105dBm to -15dBm
  • Absolute Max input power: +5dBm
  • Average noise level (typical): -100dBm
  • RF Generator amplitude: -30dBm to +1dBm
  • Frequency stability and accuracy (typical): +-10ppm
  • Amplitude stability and accuracy (typical): +-3dBm
  • Frequency resolution: 1Khz
  • Resolution bandwidth (RBW): automatic 58Khz to 812Khz
  • Weight: 185g
  • Size: 113x70x25 mm
Techsupport
This product is designed by RF-Explorer,
  • For more info and to get started with your RF Explorer, visit the start page.
  • For questions and support, please visit https://support.rf-explorer.com.
  • For the software for RF Explorer series, please click the following logo for more information:
If you'd like to buy or change the RF Explorer Battery, please click here.
認証
HSCODE9030401000
USHSCODE9030400000
UPC841454103929
EUHSCODE9030900000
COOCHINA
技術詳細
Dimensions0mm x0mm x0mm
WeightG.W 257g
BatteryLithium Cells / Batteries contained in equipment UN3481 - PI967
部品リスト
RF Explorer model 2.4G1
SKU 109990011
Pocket size and light weight Frequency band: 2400 - 2485 MHz 16hs+ of continuous run Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes Windows PC client Open Source
USD$155.00
廃番
product.detail.alsoAdd.title
