おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Internal LNA amplifier and selectable attenuator for additional power range handling.
  • Low-frequency support from 50KHz covering LF, MF, HF, VHF, and UHF
  • High-frequency support covering all ranges up to 6.1GHz with no gaps.
  • New HELP and SET buttons to improve user interface and PRESET configuration selection with 2-clicks
  • Ideal choice for all usable HAM bands.
  • Pocket size and lightweight
  • Solid metal case with high-quality varnished paint
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
  • High capacity internal Lithium battery for 10hs+ of continuous run, rechargeable by USB
  • Multi-platform Windows/Linux/MacOS Open Source software and API libraries
RF Explorer 6G COMBO+ is the most powerful Spectrum Analyzer model, covering the full 6GHz range starting at 50KHz up to 6.1GHz with no gaps or limitations.
When compared to the standard 6G Combo model, the new SLIM design offers an outstanding robust enclosure with a strong metallic body and shiny varnished paint, a more convenient USB connector on the side, and a larger internal battery capacity.
What is an RF Explorer Spectrum Analyzer?
An RF Explorer Spectrum Analyzer is a special device designed to detect very sensitive signal radiation and identify signal interference, tune antenna setups, detect signal leakage and find hidden bugs, among many other applications.
The combination of small size, great sensitivity, and robust design makes it the ideal instrument to carry on for indoor and outdoor measurements.
When connected to a computer, it can be controlled by free software available for download with stunning high-resolution graphics, data storage, and reply features.
How RF Explorer Works?
For introductory details and quick start guide, please visit www.rf-explorer.com/start
For best handling work at the desk, we recommend the RF Explorer Holder SLIM
For best results detecting near field signal sources or interferences, we recommend the RF Explorer Near Field Antenna Kit
Tip
To learn more about the RF Explorer product family, don't forget to check our blog Introducing RF Explorer Spectrum Analyzer Product Family.
Comparison Tables of Spectrum Analyzer
RF Explorer
Range
Low-frequency Support
Battery
4G Combo PLUS - Slim
50KHz - 4GHz
6G Combo PLUS – Slim
50KHz - 6.1GHz
ISM Combo PLUS - Slim
50KHz -  1GHz
2.35GHZ -             2.55GHz
from 50KHz covering LF, MF, HF, VHF and UHF up to 960Mhz
Ideal choice for HAM bands from 160meters to 33cm
 20hs+ of continuous run
 WSUB1G PLUS - Slim
 50KHz -  1GHz
Specifications
Frequency Band
  • Left connector: 0.05 – 960MHz
  • Right connector: 240 – 6100MHz
Frequency Span
2 – 960MHz in a single sweep
Internal Selectable LNA Gain
25dB
Internal selectable Attenuators
30dB and 60dB
Supporting OS
Windows, Linux and MacOS X
Resolution Bandwidth (RBW)
automatic 2.6Khz to 600Khz
Frequency Resolution
1Khz
Amplitude Stability and Accuracy (typical)
+-3dBm
Amplitude Resolution
0.5dBm
Dynamic Range
-125dBm to 10dBm
Absolute Max Input Power
+30dBm
Average Noise Level (typical LNA)
-125dBm
Wifi Analyzing Range
2.4GHz and 5GHz bands
Antenna Included
  • 2.4/5GHz dual-band antenna
  • UHF 400-900MHz rubber duck articulated antenna
  • Wideband 144/433MHz dual band telescopic antenna
SMA
Standard 50 ohms connectors
Battery
Internal Lithium-Ion 1800mA/h rechargeable battery
Applications
  • RF Spectrum Analysis for FM, TV and DTV, ISM, RFID, GSM, 4G/5G, IoT, GPS, Bluetooth
  • WiFi analysis and fine-tuning
  • Interference hunting
  • EMC pre-testing
  • RF device tuning (with Signal Generator working as Tracking SNA): Check this link for more details
  • 1 x Spectrum Analyzer
  • 1 x Mini USB cable
  • 1 x Dual band 144/430MHz Telescopic antenna
  • 1 x UHF 400-900Mhz antenna
  • 1 x Dual band 5/2.4GHz antenna
  • 1 x EVA case
Compliance
All RF Explorer models are complaint with FCC as well as CE regulations.
All RF Explorer Wideband models have been certified under EN/IEC61236 and EN/IEC61000.
All RF Explorer models are RoHS compliant
認証
HSCODE9030401000
USHSCODE9030400000
UPC841454123224
EUHSCODE9030900000
COOCHINA
RF Explorer 6G Combo PLUS - Slim Spectrum Analyzers
SKU 114992145
RF Explorer 6G COMBO+ is the most powerful Spectrum Analyzer model, covering the full 6GHz range starting at 50KHz up to 6.1GHz with no gaps or limitations.This product is a co-create collaboration with Seeed Studio and RF Explorer.
USD$449.00
product.detail.alsoAdd.title
