おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
RF Explorer is a handheld digital spectrum analyzer, a very affordable tool for work in all popular frequency bands. It is based on a highly integrated frequency synthesizer and double-balanced mixer which offers high performance, compact size, low consumption and low cost.
It has been designed to be used equally well indoor and outdoor, and can be connected to a PC for extra functionality using standard mini-USB 2.0 connector.
This model includes a 6G baseline unit plus an RFEMWSUB3G Expansion Module conveniently assembled and tested. It comes with two SMA connectors and three antennas: a nice dual band telescopic 144/430MHz wideband telescopic antenna for all Sub-GHz frequencies, a rubber duck 5.8 GHz and a whip helical for 2.4GHz band. Additional, specific band antennas may be needed to cover efficiently some of the frequencies supported.
The combination of these two models offer coverage for most used communication frequency range used in modern communication technologies including WiFi, Bluetooth, Wireless Audio and Video, LTE, GSM, GPRS, Satellite, CATV, DTV, etc.
  • Pocket size and lightweight
  • Solid aluminum metal case
  • Includes a transport EVA carry case for RF Explorer
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite, and Averaging modes
  • High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
  • Windows PC client Open Source
  • Wideband coverage to all popular RF frequencies, starting at 15MHz and going up to 2.7GHz, as well as 4.85-6.1GHz. This includes very interesting frequency areas such as 2m HAM radio, all VHF and UHF, FM radio, GPS, WiFi and WiMax, Bluetooth, etc.
Note:
This unit does not include RF Generator functionality, only Spectrum Analyzer functionality is available. For signal generator and tracking please consider RF Explorer Signal Generator model RFE6GEN.
Tech support
For questions and support, please visit https://support.rf-explorer.com
If you'd like to buy or change the RF Explorer Battery, please click here.
Compliance
All RF Explorer models are complaint with FCC as well as CE regulations.
All RF Explorer Wideband models have been certified under EN/IEC61236 and EN/IEC61000.
All RF Explorer models are RoHS compliant
認証
HSCODE9030401000
USHSCODE9030400000
UPC841454103950
EUHSCODE9030900000
COOCHINA
技術詳細
Dimensions113mm x0mm x0mm
WeightG.W 387g
BatteryLithium Cells / Batteries contained in equipment UN3481 - PI967
Frequency band15-2700 MHz and 4850-6100MHz
Frequency span
Left SMA port (6G)2-600Mhz
Right SMA port (WSUB3G)112KHz - 600MHz
2 standard SMA 50 ohms Spectrum Analyzer connectors
Left SMA port (6G)4850-6100MHz
Right SMA port (WSUB3G)15-2700 MHz
Amplitude resolution0.5dBm
Dynamic range
Left SMA port (6G)-105dBm to -15dBm
Right SMA port (WSUB3G)-110dBm to -10dBm
Absolute Max input power
Left SMA port (6G)+25dBm
Right SMA port (WSUB3G)+30dBm
Average noise level (typical)-105dBm
Frequency stability and accuracy (typical)
Left SMA port (6G)+-0.5ppm
Right SMA port (WSUB3G)+-10ppm
Amplitude stability and accuracy (typical)
Left SMA port (6G)+-3dBm
Right SMA port (WSUB3G)+-6dBm
Frequency resolution1Khz
Resolution bandwidth (RBW)
Left SMA port (6G)automatic 58Khz to 812Khz
Right SMA port (WSUB3G)automatic 3Khz to 600Khz
Graphics LCD 128x64 pixels, great visibility outdoors
PC Windows clientsupports Windows XP/Vista/Win7 both 32 and 64bits
Backlightfor great indoor visibility
部品リスト
RF Explorer 6G Combo1
Rubber duck 5.8GHz antenna1
Nagoya NA773 wideband telescopic antenna1
2.4GHz band antenna1
EVA case1
RF Explorer 6G Combo Spectrum Analyzers
SKU 109990063
USD$389.00
廃番
product.detail.alsoAdd.title
