Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  1. Open - source Software: Offer full source code, enabling community contributions and custom dev.
  2. Multi - sensor Integration: Integrate temp, light, 3 - axis accel sensors. Support GNSS, WiFi & Bluetooth for indoor/outdoor positioning.
  3. Easy Configuration: Via SenseCraft App, users can easily configure device params.
  4. Strong LoRaWAN Support: Ensure quick device network access and config.
User - friendly Buttons: Simple button ops for power on/off, Bluetooth setup, SOS alarm, etc.
Versatile LoRaWAN Connectivity – T1000-E for Your Tracking Needs
SenseCAP Card Tracker T1000-E for LoRaWAN is designed for versatile long-range tracking applications. It comes preloaded with LoRaWAN firmware out of the box, providing reliable and low-power connectivity for asset tracking and GNSS-based applications.
   1. LoRaWAN – Out-of-the-Box LoRaWAN Communication
Ideal for long-range, low-power IoT applications using public or private LoRaWAN networks.
   2. SoftRF – GNSS-based Positioning & ADS-B
Open-source firmware for peer-to-peer GNSS telemetry, ADS-B reception, and geolocation experiments.
Tip: The SenseCAP Card Tracker T1000-E for LoRaWAN comes with LoRaWAN firmware preloaded and is ready to use with LoRaWAN networks.
General Parameters
Product Model
T1000-E
Backhaul
LoRaWAN® (v1.0.4 Class A)
Bluetooth
Bluetooth v5.1, setting via SenseCraft App
LoRaWAN Channel Plan
IN865/EU868/US915/AU915/AS923/ KR920/RU864
Temperature
Range: -20 to 60℃; Accuracy: ± 1℃;
Resolution: 0.1℃
Light
0 to 100% (0 is dark, 100% is brightest )
3-Axis Accelerometer
3-Axis Accelerometer to detect movement
LED and Buzzer
1*LED and 1* buzzer to indicate status
Button
1*Button to operate and trigger events(SOS)
Antenna
Internal (GNSS/LoRa/Wi-Fi/BLE)
Communication Distance
2 to 5km (depending on gateway antenna, installation, and environments)
IP Rating
IP65
Dimensions
85 x 55 x 6.5 mm
Device Weight
32g
Operating Temperature
-20℃ to +60℃
Operating Humidity
5% - 95% (No condensation)
Certification
CE /FCC /RoHS
Location
GNSS Constellation
GPS/GLONASS/Galileo/ BeiDou/QZSS
GNSS Sensitivity
-145dBm cold start / -160 dBm Tracking
GNSS Location Accuracy
~1m CEP, GPS, -130dBm
Wi-Fi Positioning
Passive scanning, uploads the scanned 3~5 MAC addresses
Bluetooth Positioning
uploads the scanned 3 best signal MAC addresses of Beacon
Battery
Battey Capacity
Rechargeable lithium battery, 700mAh
*Battery Life Estimates
3 months on a single charge(uplink every 1 hour, only GNSS data)
Battery Life Monitoring
Periodic uplink battery level
Charge Cable (Adapter not included)
USB magnetic charging cable, 1 meter
Power Input Voltage
4.7 to 5.5V DC
Charging Temperature
0 to +45℃
Hardware Overview
Application
  • Asset Tracking: Monitor asset status and location remotely. Transmit location data to the cloud via LoRaWAN. Users can view real - time position and trajectory on mobile or PC management platforms.
  • Environmental Monitoring: Leverage built - in thermal, photosensitive sensors and 3 - axis accelerometer. Collect and upload environmental data in real time via LoRaWAN for remote parameter monitoring.
  • Logistics Management: Install on vehicles or packages. Track cargo transport status (routes, stops, on - time arrival) in real time, aiding logistics firms in scheduling and management.
Certification
HSCODE9031809090
USHSCODE8517620090
UPC
EUHSCODE9013101000
COOCHINA
Tracker T1000-E
x1
USB Cable (Adapter not included)
x1
SKU 114993591
It features open-source software. It integrates diverse sensors and positioning tech, transmitting data to the cloud via LoRaWAN for real-time device monitoring and management. As an open-source device, LoRaWAN Tracker T1000-E offers full source code, enabling developers to customize and expand functions freely.
JPY¥6316.00
