Note:
The SX1262 in the "Xiao nRF52840 & Wio-SX1262 Kit" IS NOT COMPATIBLE with the Xiao ESP32S3.
The product comes pre-flashed with LoRa single-channel gateway firmware, allowing you to start using it through the SenseCraft app in just three steps.If you're a Meshtastic user, please Flash the Firmware before using it.
Specification | Parameter |
Basic | |
Processor | ESP32-S3R8, Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz |
Memory | On-chip 8M PSRAM & 8MB Flash |
Wireless | Complete 2.4GHz Wi-Fi subsystem BLE: Bluetooth 5.0, Bluetooth mesh, LoRa: Based on Semtech SX1262, supports 862-930MHz |
Interface | 1x UART, 1x IIC, 1x IIS, 1x SPI, 11x GPIOs (PWM), 9x ADC, 1x User LED, 1x Charge LED 1x Reset button, 1x Boot button |
Power | Input voltage (Type-C): 5V Input voltage (BAT): 4.2V |
Charging battery current: 100mA | |
Operating Temperature | -40 ~ 65°C |
Antenna | |
Type | SMA to I-PEX External Antenna |
Max Gain | 2 dBi |
Dimension | 13.0x195mm |
Installation | Install on the outside of the enclosure |
Distance | 2~5km in open environment |
Application | Suitable for most scenarios, designed for indoor and outdoor |
Mechanical | |
Dimension | 22x23x57mm |
Material | ABS |
Weight | 37.1g |
Wio-SX1262 extension board diagram |
XIAO ESP32S3 front indication diagram |
XIAO ESP32S3 back indication diagram |
XIAO ESP32S3 Pin List |
The most cost-effective single-channel LoRaWAN gateway for connecting multiple LoRaWAN sensors and transmitting data to LoRaWAN Network Servers such as The Things Network and Chirpstack.
A mini LoRaWAN sensor, ideal for beginners exploring LoRa/LoRaWAN. It can be used with the XIAO extension board and Grove sensors for rapid prototyping.
What is Meshtastic?
Meshtastic is an open-source wireless communication project designed to create a mesh network system using low-power LoRa devices. This allows devices to communicate flexibly and cost-effectively without relying on traditional mobile networks or Wi-Fi. It's suitable for use in various extreme environments and outdoor activities.
If you're interested in Meshtastic, you can explore it by following the firmware flashing tutorial.
Wio-SX1262 and XIAO ESP32S3 kit with 3D-Printed Enclosure | x 1 |
2dBi-868-915MHZ-SMA Antenna | x 1 |
20cm USB type C cable | x 1 |
* Regional Availability
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
This device is based on XIAO ESP32S3 and Wio-SX1262 LoRa module. Coupled with an exquisite 3D - printed casing, it is equipped with an 868 - 915MHZ wide frequency range and 2dBi gain external antenna. It can support 2~5km single channel lorawan gateway and meshtastic communication. Through the GPIO port, it can be paired with GNSS modules and other additional modules.
