製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
If you want to buy the compatible SX1262 for the nRF52840 separately, Click here.
The SX1262 in this kit IS NOT compatible with Xiao ESP32S3.
  • Versatile Microcontroller: Incorporate the Nordic nRF52840 chip with FPU, operating up to 64 MHz, mounted multiple development ports, supported by Arduino / CircuitPython / Micropython
  • Powerful LoRa Performance: Long-range LoRa on Semtech SX1262, supports 868/915 MHz bands.
  • Dual-core communication: It supports both Bluetooth and LoRa dual modes, enabling cross-domain interconnection.
  • With dimensions of only 8mm × 22mm × 23mm, it features an integrated antenna design.
仕様
XIAO nRF52840
Nordic nRF52840
ARM® Cortex®-M4 with FPU runs up to 64 MHz
Wio-SX1262
Based on Semtech SX1262, supports 862-930MHz
Wireless
Bluetooth 5.0/NFC
Interface
XIAO nRF52840:1x UART, 1x IIC, 1x SPI(connect to SX1262),1x NFC, 1x SWD, 11x GPIO(PWM), 6x ADC
Wio-SX1262:1xSPI(connect to XIAO nRF52840)
Power
Input voltage (Type-C): 5V
Input voltage (BAT): 4.2V
Charging battery current: 50mA/100mA
Standby power consumption: <5uA
Working Temperature
-40°C ~ 65°C
Dimensions
21 x 17.8mm
ハードウェア概要
XIAO nRF52840
  • Onboard
  • PinOut
Wio-SX1262
  • Onboard
  • PinOut
用途
  • Meshtastic Node&Router: An ultra-small node that can serve as a portable device or as a fixed router to expand the Meshtastic network.
  • LoRa/LoRaWAN Sensor: A mini LoRaWAN sensor, ideal for beginners exploring LoRa/LoRaWAN.
    For example, when combined with a GPS module (such as the XIAO L76K), it can be used to track the locations of logistics vehicles, livestock, and valuable equipment. Thanks to the long-distance coverage of LoRa (2-5 km in urban areas and over 10 km in suburban areas), it can reduce the cost of base station deployment.
  • The distance between the two nodes can reach up to 2KM (subject to the environment).
認証
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
XIAO nRF52840
x1
Wio-SX1262 extension board
x1
LoRa antenna
x1
* Regional Availability
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
XIAO nRF52840 & Wio-SX1262 Kit for Meshtastic
SKU 102010710
This kit combines the XIAO nRF52840 and Wio-SX1262, supporting BLE5.0 and LoRa (862-930MHz), and operates with low power consumption. It can be applied in various fields such as Meshtastic, sensor networks, environmental monitoring, asset tracking, education, and innovation.
JPY¥2136.00
