おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • The device is compatible with Meshcore firmware. Please click here to follow the tutorial.
  • SenseCAP Solar Node P1 is cost-effective and lacks the XIAO L76K GPS module and four 18650 batteries. But users can buy and install them independently. For the model with positioning and batteries, opt for the SenseCAP Solar Node P1-Pro.
  • To add battery, use Button-top 18650 battery.  Click here to see the reference battery.
  • Integrated with a 5W solar panel, and supports external batteries (which need to be provided by users themselves).
  • The device comes pre-installed with Meshtastic firmware at the factory. It can be seamlessly integrated into the Meshtastic ecosystem.
  • Compatible with the Grove Ecosystem (The list of supported sensors is provided below.), and supports plug-and-play of sensors such as temperature and humidity sensors, light sensors, etc.
  • It is suitable for long-term outdoor use.
  • Supports 8 to 9KM Transmission in open areas. It can be used as an outdoor node or repeater, easily expanding the Mesh network and enhancing network coverage.
  • Accessory Options:If you need an antenna with higher gain, we recommend these antennas:
    860-930MHz-3dBi-360mm
    900-930MHz-7dBi-920mm
    902-930MHz-8dBi-1300mm
    • Plug-and-play: Comes with a standard RF cable, which can be directly inserted into the pre-drilled hole (standard D-shaped hole) on the Solar Node bracket
    • Three-step installation: Align → Insert → Lock
仕様
Main controller
XIAO nRF52840 Plus(Nordic nRF52840, ARM® Cortex®-M4 32-bit processor with FPU, 64 MHz, 256KB RAM, 1MB Flash, 2MB onboard Flash)
LoRa Module
Wio-SX1262 Module(Semtch SX1262, TXOP=22dBm@862-930MHz)
GPS Module
Users self-purchase and addXIAO L76K(Support GPS/GLONASS/Galileo)
Antenna
LoRa:
Type: Rod-shaped rubber antenna
Frequency range: 868-915MHZ
Gain: 2dbi
GNSS:
GPS L1 C/A: 1575.42MHz
GLONASS L1: 1602MHz
BeiDou B1: 1561.098MHz
Bluetooth 5.0
Solar Panel
5W
Interface
Grove *1: IIC/GPIO
USB-C debugging
Button
Power on/off
Reset
User-defined
LED
Charging status indicator lights *2
Solar panel status indicator light *1
Mesh heartbeat light *1
User-defined *1
Power supply
5V
Battery
Dimension
191.2 x 201.2 x 42.1 mm
ハードウェア概要
  • Diagram
  • Overall effect diagram
  • Accessories diagram
    ①
    2dbi, 868~915MHz rubber rod antenna
    ②
    Universal joint bracket, angle adjustable.
    ③
    Bracket connector, can support the antenna
    ④
    RF Cable; RP-SMA Male to RF-SMA Female; 300mm
    ⑤
    Hoop bracket
    Diameter:
    70-100mm
    ⑥
    Hoop ring
  • Interactive items
    ⑦
    Power switch
    ⑧
    Reset
    ⑨
    User-defined
    ⑩
    Red light on: Charging
    ⑪
    Green light on: Charged
    ⑫
    Yellow light on: Device is exposed to light.
    ⑬
    Blue light: Mesh heartbeat
    ⑭
    White light: User-defined
    ⑮
    Type-C: 5V 1A
  • Dimension diagram
用途
  • Outdoor Adventure: Send real-time location and text messages in areas without network coverage.
  • Mesh Network Expansion: Serve as a Mesh relay node to expand the coverage of the existing Meshtastic network. Support multi-hop transmission, where data can be relayed through multiple nodes, enhancing network reliability.
  • Educational Experiments: Learn about the development of Meshtastic and LoRa decentralized networks.
  • Environmental Monitoring: Provide a Grove interface to connect sensors for remote monitoring of the environment (such as temperature, humidity, air quality, etc.).
認証
HSCODE8541430000
USHSCODE8517620090
UPC
EUHSCODE8531202090
COOCHINA
部品リスト
SenseCAP Solar Node P1 (without GPS & battery)
x1
Mounting Brackets
● Universal Joint
● Connector
● Hoop Bracket
● Hoop Ring
x1
2dBi 868 - 915MHz Rubber Rod Antenna
x1
RF Cable; RG316 coaxial cable; RP-SMA Male to RF-SMA Female; 300mm
x1
1/4-20 UNC Hex Head Machine Screw, 6 mm Long(Screw Pack)
x2
Screw, Phillips Pan Head Machine, M6 × 14 mm, P1.0(Screw Pack)
x4
Black Type-C Cable
x1
User Manual
x1
* Regional Availability
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
SenseCAP Solar Node P1 for Meshtastic
SKU 114993643
It is an economical solar-powered comms node or repeater based on Meshtastic. It meets basic comms needs in no - network zones. Unlike P1-Pro, P1 lacks a built-in GPS module and four 18650 batteries, yet keeps core comms. It's perfect for budget-constrained scenarios or those not needing precise location, like environmental monitoring and short - range network setups.
JPY¥10384.00
¥11539.00
Save ¥1155.00(10%)
product.detail.alsoAdd.title
