おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
The WM1110 development kit is based on Wio-WM1110 Wireless Module and integrates Semtech's LoRa® transceiver and a multi-purpose radio front-end for geolocation.
The LoRa® transceiver provides low-power, high-sensitivity network coverage, while GNSS (GPS/Beidou) and Wi-Fi scanning offer all-around location coverage.
SenseCAP WM1110 Dev Kit provides a complete solution for developers looking to create IoT applications that require low-power, long-range communication, and precise location tracking capabilities, while also providing connectivity options for a variety of peripherals.
Note
  • Wio-WM1110 module has been perfectly applied to SenseCAP T1000, SenseCAP T1000 is a LoRaWAN® card size tracker for seamless indoor & outdoor positioning. It boasts months of battery life and is equipped with temperature, light, and motion sensors, making it ideal for a variety of location-based applications.
  • Low-Power High-Sensitivity LoRa/(G)FSK Half-Duplex RF Transceiver: Frequency bands support in the range 863- 928MHz
  • Multi-Purpose Radio Front-End for Geolocation: GNSS (GPS/ BeiDou)、Wi-Fi、Bluetooth
  • Rich GPIOs and Compatible with Grove: Over 400 Grove-compatible for flexible expansion options.
  • Open Source Platform: Leverage the extensive LR1110 and nRF52840 open-source ecosystem for infinite application possibilities.
  • Built-in Sensors and Multiple Power Supply Modes: Temp&Humidity sensor and 3-Axis accelerometer, support both solar power and battery-powered.
仕様
LoRa® and Positioning (Semtech LR1110)
LoRa®WAN Protocol
V1.0.4
Frequency
863~928MHz
Sensitivity
-125dBm @125K/SF7
-141dBm @125K/SF12
Output Power
20dBm max @LoRa®
Positioning Technology
GNSS(GPS,BeiDou),WiFi
Range
2~10km (Depends on antenna and environment)
Bluetooth(Nordic nRF52840)
Bluetooth
Bluetooth 5.3
Flash
1MB
RAM
256KB
Protocol
Bluetooth LE, Bluetooth mesh, Thread, Zigbee, 802.15.4, ANT and 2.4 GHz proprietary stacks
Output Power
6dBm max @Bluetooth
Built-in Sensors
TH Sensor (SHT41)
Range
Accuracy
Temperature
-40~125°C
0.2°C
Humidity
0~100%RH
1.8%RH
3-Axis Accelerometer(LIS3DHTR)
Range
±2g, 4g, 8g, 16g
Bandwidth
0.5Hz ~ 625Hz
Sensitivity (LSB/g)
1000 (±2g) ~ 83 (±16g)
General
Voltage - supply
3.3V (USB 2.0 Type-C)
Solar Panel(optional)
0.5W/100mA
The power supply will charge the ultracapacitor.
Battery(optional)
AAA Battery x3
4.5V, each battery is 1.5V
Interface
RFIO
Bluetooth Antenna x1
WiFi Antenna x1
GNSS Antenna Connector x1
LoRa Antenna Connector x1
NFC Antenna IPEX x1
USB type-C
x1
Grove Interface
GPIO(A6/A7) x1
I2C x1
UART x1
GPIO
Arduino Compatible Connectors
Button
BTN1
Configurable button
BTN2
Configurable button
RST
Reset
Low Power LoRa® Transceiver
Benefiting from Semtech‘s LoRa Edge™ LR1110, the Wio-WM1110 Dev Kit provides long-distance, low-power LoRa® communication. To learn about Long Range and its features such as network architecture and applications, you can check out An Introduction of LoRa® and LoRaWAN® technology, It explains what Long Range is, how it works, and its pros and cons.
Location Service
The Wio-WM1110 Dev Kit integrates Multi-Purpose Radio Front-End Targeting Geolocation Purposes. It's equipped with GNSS dedicated to outdoor positioning, as well as Wi-Fi and Bluetooth scanning for indoor positioning. It's able to automatically transition between outdoor and indoor activities, replacing the need to build different trackers for indoor or outdoor use, this provides all-around location coverage while reducing complexity and cost.
Outdoor Positioning(GNSS)
The Wio-WM1110 Dev Kit integrates GNSS (GPS/ BeiDou) low-power scanning,
getting data from satellites and sending it encrypted to the LoRa® Cloud, reducing power consumption and improving security.
IPS(Wi-Fi+Bluetooth)
Complementary to outdoor GNSS, WM1110 Dev Kit also supports Wi-Fi ultra-low-power passive scanning and Bluetooth scanning suitable for indoor positioning, it scans the MAC address and RSSI of nearby Bluetooth beacons/Wi-Fi, upload the data to the cloud services to get the accurate location.
Rich peripherals
In addition to the built-in TH sensor and 3-axis Accelerometer, this kit also includes a series of peripheral interfaces and supports ADC/UART and IIC transmission protocols, which can be connected to 400+ Grove modules, allowing for easy upgrades to smarter solutions. It's also compatible with Arduino, providing developers with unlimited possibilities.
Develop User Applications
Wio-WM1110 Dev Kit is a fully open-source powerful IoT development platform for developers, also includes a set of example applications and code samples, as well as a software development kit (SDK) to help you get started.
Schematic Diagram
Hardware Overview
Pinout
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Wio-WM1110 Dev Board
x1
LoRa Antenna(868~915MHz)
x1
GPS Antenna
x1
Solar Panel(55*70mm/0.5W)
x1
Wio-WM1110 Dev Kit, built-in Semtech LR1110 and Nordic nRF52840
SKU 114993082
The Wio-WM1110 Dev Kit is an all-in-one solution for developing low-power, long-range IoT positioning applications. Based on Wio-WM1110 Wireless Module, features Semtech's LoRa® technology for long-range wireless communication, GNSS, and Wi-Fi for location tracking, and also supports Bluetooth Low Energy, Bluetooth mesh, NFC, Thread, and Zigbee.
USD$32.90
product.detail.alsoAdd.title
