おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
The Wio Tracker 1110 Dev Board is based on Wio-WM1110 Wireless Module and integrates Semtech's LR1110 LoRa® transceiver and a multi-purpose radio front-end for geolocation, it's a user-friendly, LoRa-based tracking development platform.
With its compact size and rich Grove interfaces, the Wio Tracker 1110 Dev Board is conveniently equipped with onboard antennas for easy deployment. It supports the Arduino development environment and LoRaWAN® protocol stack, making it ideal for tracking-related IoT projects.
  • Powerd by Nordic nRF52840 and Semtech LR1110
  • Offers multiple connectivity options including: LoRa®, GNSS(GPS/BeiDou), Bluetooth, Wi-Fi Sniffer
  • Supports over 300+ Seeed Grove Sensors: making it highly adaptable for different tracking and sensing requirements.
  • Onboard temperature sensor, humidity sensor, and a 3-axis accelerometer: capturing a wide range of environmental and motion data
  • Fully Open Source Platform: Leverage the extensive LR1110 and nRF52840 open-source ecosystem for infinite application possibilities.
  • Arduino IDE compatibility: allowing ease of programming and a familiar environment for developers.
仕様
LoRa® and Positioning (Semtech LR1110)
LoRaWAN® Protocol
V1.0.4
Frequency Plan
863~928MHz
Sensitivity
-125dBm @125K/SF7
-141dBm @125K/SF12
Output Power
20dBm max @LoRa®
Positioning Technology
GNSS(GPS/BeiDou), WiFi Sniffer
Range
2~10km (Depends on antenna and environment)
Bluetooth(Nordic nRF52840)
Bluetooth
Bluetooth 5.3
Flash
1MB
RAM
256KB
Protocol
Bluetooth LE, Bluetooth mesh, Thread, Zigbee, 802.15.4, ANT and 2.4 GHz proprietary stacks
Output Power
6dBm max @Bluetooth
General
Voltage - supply
5V (USB 2.0 Type-C)
Battery Connector
3.7V
Interface
RFIO
GNSS Antenna Connector* 1
LoRa Antenna Connector* 1
USB type-C
* 1
Grove Interface
ADC* 1I2C* 1UART* 1
Digital*3
Button
USER
Configurable button
RESET
Reset
Exterior FLASH Memory
4M
Onboard Sensors
TH Sensor (SHT41)
Range
Accuracy
Temperature
-40~125°C
± 0.2°C
Humidity
0~100%RH
±1.8%RH
3-Axis Accelerometer(LIS3DHTR)
Range
±2g, 4g, 8g, 16g
Bandwidth
0.5Hz ~ 625Hz
Sensitivity (LSB/g)
1000 (±2g) ~ 83 (±16g)
Low Power LoRa® Transceiver
Benefiting from Semtech's LR1110, the Wio-Tracker 1110 Dev Board provides long-distance, low-power LoRa® communication. To learn about Long Range and its features such as network architecture and applications, you can check out An introduction of LoRa® and LoRaWAN® technology, It explains what Long Range is, how it works, and its pros and cons.
Multiple positioning technologies
The Wio-Tracker 1110 Dev Board integrates Multi-Purpose Radio Front-End Targeting Geolocation Purposes. It's equipped with GNSS(GPS/BeiDou) dedicated to outdoor positioning, as well as Wi-Fi Sniffer and Bluetooth scanning for indoor positioning. It's able to automatically transition between outdoor and indoor activities, replacing the need to build different trackers for indoor or outdoor use, this provides all-around location coverage while reducing complexity and cost.
Rich peripherals
In addition to the onboard temperature and humidity sensor(SHT41) and 3-axis accelerometer(LIS3DHTR), it features a series of peripheral interfaces, and supports ADC/UART and IIC transmission protocols, which can be connected to 300+ Grove modules, enabling easy upgrades to smarter solutions.
Quick Start Demo
We provide a plug-and-play demo, where users can simply scan a QR code, connect the power, get location and sensor data on the SenseCAP Mate APP within 5 minutes.
Develop User Applications
Wio-Tracker 1110 Dev Board is a fully open-source powerful IoT development platform, compatible with Arduino IDE, it comes with a set of example applications and code samples to help you get started smoothly and quickly.
ハードウェア概要
認証
HSCODE8517180050
USHSCODE8517620010
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
x1
Plastic Packing Box
x1
Wio Tracker 1110 Dev Board- the Tracker Prototype for Indoor and Outdoor Positioning
SKU 114993186
Enhance your tracking and environmental monitoring applications with the Wio Tracker 1110 Dev Board - Unleashing indoor and outdoor positioning power through LR1110 and Nordic nRF52840 chips, LoRa®, Bluetooth, GPS, and Grove Capabilities.
USD$29.90
product.detail.alsoAdd.title
