おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
The device does not come with GPS. If you want to use GPS, please click the link to purchase it.
  • Supports Meshtastic: Pre-flashed with Meshtastic firmware, it is ready to work once powered on. You can also upgrade the firmware using Meshtastic Flasher.
  • Dual MCUs and Rich GPIOs: Equipped with powerful ESP32S3 and RP2040 dual MCUs and over 400 Grove-compatible GPIOs for flexible expansion options.
  • Local LoRa® Hub for IoT Connectivity: Integrated with the Semtech SX1262 LoRa® chip, the device can be converted to a LoRaWAN® Single-Channel Gateway via tutorial. Alternatively, connect LoRa® devices to popular IoT platforms like Matter via Wi-Fi.
  • Fully Open Source Platform: Leverage the extensive ESP32 and Raspberry Pi open-source ecosystem for infinite application possibilities.
  • Suitable for Multiple Application Scenarios: Can be used as a Meshtastic desktop node or a car node, as well as a LoRaWAN® Single-Channel Gateway.
仕様
Screen
3.95 Inch, Capacitive RGB Touch Screen
Screen Resolution
480 x 480 pixels
Power Supply
5V DC, 1A
Battery
N/A
Processor
ESP32-S3: Xtensa® dual-core 32-bit LX7 microprocessor, up to 240MHz
RP2040: Dual ARM Cortex-M0+ up to 133MHz
Flash
ESP32S3: 8MB
RP2040: 2MB
External Storage
Support up to 32GB Micro SD Card (not included)
LoRa
Supports 862-930MHz
Wi-Fi
802.11b/g/n, 2.4GHz
Bluetooth
Bluetooth 5.0 LE
Certification
CE /FCC
Buzzer(Not developed yet)
MLT-8530, Resonant Frequency:2700Hz
ハードウェア概要
用途
Meshtastic®
As a Meshtastic device, it can build an open-source, off-grid, decentralized, and free LoRa mesh network for reliable long-range, low-power communication with other Meshtastic® nodes. Pair it with your phone in three steps to start communicating with nearby nodes via the Meshtastic app, check signals, and share locations without any network infrastructure.
Recommended Use Cases
LoRa®
You can transform the device into a single-channel gateway by flashing the firmware, allowing it to receive and send data from LoRa terminal devices. This is a cost-effective option, especially suited for scenarios that require simple, low-power wireless communication.
認証
HSCODE8543709990
USHSCODE8531200020
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Indicator
x1
USB-C Cable(1M)
x1
2dBi-868-915MHZ-SMA Antenna
x1
SenseCAP Indicator for Meshtastic® & LoRa®
SKU 114993532
It is a 4-inch touchscreen device designed for Meshtastic®, powered by dual MCUs, the ESP32 and RP2040, and supports Wi-Fi, BLE, and LoRa®. It is an open-source, powerful IoT development platform.
JPY¥9639.00
product.detail.alsoAdd.title
