おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
Note
  • SKU 114992549: WM1302(SPI - EU868) with SX1262.
  • SKU 114993268: WM1302(SPI - EU868) without SX1262.
If your design doesn't require Listen Before Talk (LBT), consider choosing SKU 114993268. This SKU is currently in stock, resulting in shorter lead times and making it a preferable option for purchase.
However, if you must purchase SKU 114992549, we will arrange a production order specifically for your purchase. But please note that the lead time for this SKU is longer.
  • Powered by SX1302 baseband Wio chip, extremely low power consumption and high performance.
  • Mini-PCIe form factor with the standard 52-pin golden finger, easy to integrate with various gateway devices.
  • Ultra-low operating temperature, no additional heat dissipation needed, reducing the size of Long-Range gateway.
  • High sensitivity down to -139 dBm @SF12 with SX1250 TX/RX front-end; TX power up to 26 dBm @3.3V.
  • Certified with CE(EU868), FCC ID(US915), and TELEC(AS923). Simplify the final product certification process.
WM1302 module is a new generation of Long Range gateway module with a mini-PCIe form factor. Based on the SX1302 baseband Wio chip, WM1302 unlocks the greater potential capacity of long-range wireless transmission for gateway products. It features higher sensitivity, less power consumption, and lower operating temperature than the previous SX1301 and SX1308 Wio chips.
WM1302 Long Range gateway module has SPI and USB versions on both US915 and EU868 frequency bands, enabling you to have a wide range of Long Range frequency plans options to choose including EU868, US915, AS923, AS920, AU915, KR920, and IN865.
WM1302 module(EU868) is CE certified, which helps simplify the development and certification process of the Long Range gateway devices.
WM1302 is designed for M2M and IoT applications and can be widely applied in LPWAN gateway-supported scenarios. It would be a perfect choice for you to significantly reduce the technical difficulties and time-consumption when developing the Long Range gateway devices, including Long Range gateway, etc.
仕様
Region
EU868
US915
Frequency
865-870MHz
902-928MHz
Sensitivity
-125dBm @125K/SF7
-139dBm @125K/SF12
-125dBm @125K/SF7
-139dBm @125K/SF12
TX Power
13.65 dBm (with 3.3V power supply)
25 dBm (with 3.3V power supply)
LEDs
Power: Green Config: Red TX: Green RX: Blue
Form Factor
Mini PCIe, 52pin Golden Finger
Power Consumption (SPI version)
Standby: 7.5 mA
TX maximum power: 415 mA
RX: 40 mA
Power Consumption (USB version)
Standby: 20 mA
TX maximum power: 425 mA
RX: 53 mA
LBT(Listen Before Talk)
Unsupported
Antenna Connector
U.FL
Operating Temperature
-40°C to 85°C
Dimensions
30 mm (width) × 50.95 mm (length)
Certification
CE (EU868), FCC ID (US915), TELEC (AS923)
ハードウェア概要
Diagram
Pinout
用途
  • LPWAN Gateway devices development
  • Any long-distance wireless communication application development
  • Long Range application learn and research
認証
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio-WM1302 Long Range Gateway Module without SX1262(SPI) - EU868
SKU 114993268
WM1302 module is a new generation of Long Range gateway module in mini-PCIe form-factor based on Semtech® SX1302 but without the SX1262. It features extremely low power consumption, and outstanding performance with CE certification.
Version
Region
SX1262
USD$34.90
product.detail.alsoAdd.title
