おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
Note
Please click here to contact us if you need any further information on Seeed IIoT products and services. We are excited to see you can scale up and expand your business with our products and services.
  • Standard Pi Hat form factor with 40 pins female pin header
  • Raspberry Pi versions up to 4B compatible
  • GPS Module embedded
  • LoRaWAN authentication chip embedded
WM1302 Pi HAT is an add-on expansion board designed specifically for attaching the WM1302 LoRaWAN Gateway module(SPI) based on SX1302 to Raspberry Pi versions up to Raspberry Pi 4B. It also integrates the LoRaWAN authentication chip and GPS module.
WM1302 module is a new generation of LoRaWAN gateway module with mini-PCIe form-factor. Based on the Semtech® SX1302 baseband LoRaWAN® chip, WM1302 unlocks the greater potential capacity of long-range wireless transmission for gateway products. It features higher sensitivity, less power consumption, and lower operating temperature than the previous SX1301 and SX1308 LoRa® chip.
WM1302 Pi HAT supports the WM1302 module's mini-PCIe form-factor and can automatically configure the standard 52-pin golden fingers to the Raspberry Pi GPIO connector with a 40-pin compatible header. This simplifies the development process for users to integrate with Raspberry Pi. WM1302 Pi HAT works as an extension board and helps add the functionality of SX1302 on the Raspberry Pi, to support LoRaWAN and LoRa protocols for long-range wireless transmission. The GPS module integrated also enhances the accuracy of timing and location of the WM1302 module.
WM1302 Pi HAT, together with the WM1302 Gateway Module and Raspberry Pi, can help construct your very completed and compacted LoRaWAN wireless communication gateways supporting smart agriculture, smart cities, and other IoT scenarios.
仕様
Dimensions56*65mm
Weight0.501
Operating Voltage5V
Power Interface40 Pin Header or USB
Raspberry Pi 40-Pin HeadersSupport Raspberry Pi 5
Support Raspberry Pi 4 B
Support Raspberry Pi 3 A+/B/B+
Support Raspberry Pi 2 B
Support Raspberry Pi A+/B+
Support Raspberry Pi Zero/Zero W
PCIe Header52 Pin Mini-PCIe Header
GNSSSuport GPS L1, GLONASS L1, BeiDou B1
BatteryExclude
ハードウェア概要
用途
  • LoRaWAN Gateway device/hotspot development
  • Long-distance wireless communication application development
  • Any learning and experimentation based on Raspberry Pi
  • LoRa and LoRaWAN application learn and research
認証
HSCODE8517709000
USHSCODE8517620090
UPC
EUHSCODE8543909000
COOCHINA
部品リスト
Part List:
WM1302 Pi Hat *1
GPS Antenna *1
M2.5*6mm Screw *8
M2.5*11.0mm Stud *4
M2.0*H6.0mm Screw *2
WM1302 Raspberry Pi Hat
SKU 113100022
WM1302 Pi HAT is a Raspberry Pi add-on board for connecting the WM1302 LoRaWAN module, based on LoRa Concentrator Semtech SX1302. It supports mini-PCIe form-factor and simplifies the development process for users to integrate with all Raspberry Pi versions up to Raspberry Pi 4B.
USD$19.90
product.detail.alsoAdd.title
