製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Support TensorFlow Lite
  • Onboard SD Card Slot
  • Onboard 3.5mm Audio Jack / Microphone
  • Ultra-low power consumption suitable for IoT applications
  • Latest high-security architecture with secure boot
  • Dual Arm® powered CPUs for higher performance
  • Fast wireless speeds with the latest wireless technologies such as Wi-Fi 5GHz and BLE5
  • Rich I/O peripherals to further expand your projects
  • Wide environment Compatibility:
    • Windows XP/7/8/10 32-bits and 64-bits
    • Linux
    • Mac
  • Compatible with Arduino
Ameba RTL8722DM mini Board (AMB 23) integrates the RTL8722DM SoC which is the latest generation SoC of the Ameba IoT solution family and it is powered by a high-performance 32-bit dual MCU with a new architecture from Arm®; an Arm®v8M (Cortex-M33 instruction set compatible) running at up to 200MHz and an Arm®v8M (Cortex-M23 instruction set compatible) running at up to 20MHz.
This SoC also integrates the latest high-security architecture (Trustzone-M Security) with ultra-low power consumption suitable for IoT (Internet of Things) applications. Besides the high-performance MCU, RTL8722DM SoC also integrates the latest wireless technologies such as dual-band Wi-Fi (2.4GHz/5GHz) and Bluetooth Low Energy (BLE5) mesh.
Ameba RTL8722DM mini Board (AMB 23) features rich I/O peripherals such as a high-speed SDIO and USB interface, audio codec, key-scan and touch key, LCD panel controller, embedded 4.5MB SRAM(512KB SRAM + 4MB PSRAM), and configurable GPIOs that can function as digital peripherals for various applications. Through these interfaces, AmebaD can connect with electronic components such as LED, switches, manometer, hygrometer, PM2.5 dust sensors, …etc. All-in-all Ameba RTL8722DM mini Board (AMB 23) is an easy-to-program platform for developing all kinds of IoT applications.
Ameba RTL8722DM_MINI currently supports Windows XP/7/8/10 32-bits and 64-bits, Linux and Mac operating systems. Now, we can use Arduino IDE to develop applications on RTL8722DM_MINI, and the examples of Arduino can run on RTL8722DM_MINI too.
In addition to features found on the regular RTL8722DM, the new mini development board also reduces the size to better fit into your projects.
AmebaD Development Boards
Board Name
RTL8722DMRTL8722DM MINI
Board SizeBig(71.3mm x 78mm)Small(37mm x 60mm)
SDIO/SD card                  Need extra hardware                                                            On-board MicroSD slot
On-boardNeed extra hardwareAudio Jack integrated
On-board LEDNox2 (Blue & Green)
On-board ButtonNox1
SPIx2x1
I2Cx2x1
PWMx13x9
GPIOMax. 54Max. 23
仕様
MCU32-bit Arm®Cortex®-M4, up to 200MHz
32-bit Arm®Cortex®-M0, up to 20MHz
Memory512KB SRAM
4MB PSRAM
Wi-Fi802.11 a/b/g/n 1x1, 2.4GHz & 5GHz
Wi-Fi simple config
BluetoothBLE 5
Supports both central and peripheral modes
Internal co-existence mechanism between Wi-Fi and BT to share the same antenna
SecurityAES/DES/SHA hardware engine
Arm TrustZone-M
Secure boot
Secure eFuse
AudioAudio DAC and earphone driver
Audio ADC
I2S
Human-Machine InteractionKey-matrix
Cap-Touch
Peripheral Interfaces1 PCM interface
3 UART interface
1 I2C interface
7 ADC
1 SPI
9 PWM
Max 23 GPIO
1 Switch button
ハードウェア概要
用途
  • Smart Home
  • Smart City
  • Smart Agriculture
  • Industrial IoT
  • IoT Hub/Gateway
  • Smart Toys
  • Wi-Fi Audio/Entertainment device
  • Gaming Joystick / Wi-Fi remote controller
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
Ameba RTL8722DM mini Board - Wireless Dev. Board/ Cortex M4 / TensorFlow Lite
SKU 113030023
Enter the promo code RTL8722DM, the early bird price is only $17.99! Ameba RTL8722DM_MINI  EVB is an easy-to-program platform for developing all kinds of IoT applications.  It integrates the RTL8722DM SoC with the latest high-security architecture and is equipped with various peripheral interfaces, including WiFi, GPIO INT, I2C, UART, SPI, PWM, ADC with ultra-low power consumption.
JPY¥4733.00
廃番
