Note:
This product includes the Grove Base Shield V2.0 for Arduino only. No Grove modules, sensors, cables, or other accessories are included.
Arduino Uno is one of the most widely used Arduino boards, but a project with more than a few sensors quickly turns into a mess of breadboards and jumper wires. Grove Base Shield V2.0 solves this by breaking out every pin on an Arduino-Uno-shaped board into 16 standardized Grove connectors, so Grove modules can be connected directly without a breadboard or soldering. The shield's pinout is the same as Arduino Uno R3, and an onboard 5V/3.3V power switch keeps it compatible with both 5V boards (e.g. Arduino Uno, Mega) and 3.3V boards (e.g. Arduino Due).
No More Jumper Wires: Grove's keyed connectors replace tangled breadboard wiring.
Save Time on Setup: modules plug in directly, with no wiring diagrams to follow.
Learn More Easily: a clear, physical layout makes it easier to see how a circuit is wired.
Easy to Expand Your Projects: add more Grove modules without redoing existing wiring.
The Grove Base Shield V2 is designed to simplify Arduino prototyping by transforming standard GPIO headers into dedicated Grove interfaces. Instead of spending time on breadboards and jumper wires, you can connect Grove modules directly through Analog, Digital, UART, and I2C ports, making hardware development faster, cleaner, and significantly easier to manage.
Built around the Grove plug-and-play ecosystem, the Base Shield V2 provides instant access to more than 300 Grove modules, including sensors, displays, actuators, communication modules, and AI peripherals. The onboard 5V/3.3V power switch allows the same shield to work seamlessly with both 5V and 3.3V Arduino-compatible boards, while its Uno R3-compatible layout ensures broad compatibility with Arduino Uno, Mega, Leonardo, Due, Zero, Seeeduino, and LinkIt ONE. Whether you're learning electronics, building STEM projects, or rapidly validating hardware prototypes, Grove Base Shield V2 lets you spend less time wiring and more time creating.
Simplify your Arduino prototyping with the Grove Base Shield V2. Instead of spending time on breadboards and jumper wires, simply plug Grove modules directly into dedicated Analog, Digital, UART, or I2C ports and start building in minutes. Fully compatible with 300+ Grove modules, the shield makes it easy to prototype, learn, and expand projects while maintaining clean, reliable wiring. With support for both 5V and 3.3V development boards, plus broad compatibility across Arduino Uno, Mega, Leonardo, Due, Zero, Seeeduino, and LinkIt ONE, it's the fastest way to bring hardware ideas to life.
Watch how easy hardware prototyping can be. From sensor connections to complete Arduino applications, this video showcases the advantages of Grove's standardized plug-and-play interface. Spend less time wiring and troubleshooting, and more time creating projects that can be easily expanded with hundreds of Grove modules as your ideas grow.
Parameter | Value |
Operating Voltage | 3.3V / 5V |
Operating Temperature | -25 °C ~ +85 °C |
Analog Ports | 4 (A0–A3) |
Digital Ports | 7 (D2–D8) |
UART Ports | 1 |
I2C Ports | 4 (shared bus) |
Total Grove Connectors | 16 |
Dimensions | 69 × 53 mm / 2.72 × 2.09 in |
Note
Boards not listed above may still work with extra jumper wiring or minor code changes — for help, reach out via Seeed Tech Support
Note
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumper wires or soldering are required. We have developed over 300 Grove modules covering a wide range of applications to meet diverse project needs. In addition to open-source hardware, we also provide open-source software to help you get started quickly.
Note
The Arduino Shield share the same header layout as Arduino development boards, allowing them to be stacked directly onto compatible boards to add new functionality. We have compiled a list of more than 20 of the most useful Arduino shields to help you unlock even more possibilities for your Arduino projects. Check our blog to learn more about Arduino Shields!
技術仕樣
| 寸法 | 69mm x53mm x23mm |
| 重さ | G.W 40g |
| バッテリー | なし |
部品リスト
| Base Shield V2 | 1 |
Arduino Unoはこれまでで最も人気のあるArduinoボードですが、物作りには大量のセンサーやLedが必要で、ジャンパー線が混乱していると面倒なことになりますね。Grove-Base Shieldは混乱しているブレッドボードとジャンプワイヤを改善することができです。ベースボード上の各groveコネクタを使用して、すべてのgroveモジュールをArduino Unoに便利に追加できます!
