製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
SAFETY NOTICE:
Magnetic connectors must be kept apart to prevent attraction and potential short circuits when in use.
  • Designed for T1000-E Devices: A dedicated charging accessory that can power up to six T1000-E devices simultaneously, delivering an efficient and convenient charging experience.
  • PCBA Board Design: Built with a high-quality PCBA board, offering structural stability for safe and reliable long-term use.
  • Multi-Cable Magnetic Connection: Equipped with six 4-pin magnetic cables for quick, secure connections, enhancing charging efficiency.
  • Customizable Casing: Allows users to design a custom casing using the provided 3D shell file to meet various usage needs.
仕様
Parameter
Input Voltage
DC 5V
Maximum Output Current
2A
Power Input Interface Type
Type-C
Power Output Interface Type
Magnetic 4-pin / 2.5mm pitch
用途
With the casing added, it supports simultaneous charging for multiple T1000-E devices, reducing wait time for charging.
ドキュメント
認証
HSCODE8504909090
USHSCODE8504904100
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
PBCA
x1
Magnetic cable
x6
Card Tracker T1000-E Charger Accessory -- PCBA with 6 magnetic cables
SKU 114993534
This accessory is specifically designed for charging T1000-E devices and can charge up to six T1000-E units simultaneously. It features a PCBA board and includes six magnetic cables. Users can customize the casing based on the provided 3D shell file, allowing flexibility to meet various usage scenarios.
JPY¥1251.00
