製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
This prodeuct only fit the T1000-E tracker. Due to the use of 3D printing technology, there may be slight differences between the images and the actual product.
  • Multi-scene Application:Supports multiple angles of fixation (including inverted), adapting to a variety of scenes such as desktop and wall.
  • Dual Fixing Solution:The back of the device is reserved for screw holes, which can be suspended from screws; it can also be directly adhered to a flat surface using adhesive stickers.
  • Hidden Cable Routing: Internal integrated cable slot design, charging cable leads from the top to avoid clutter and maintain a minimalist appearance.
  • Lightweight Construction :3D printing process realizes a lightweight body, combining durability and minimalist style.
仕様
Length
9.6mm
Width
6.6mm
Height
8mm
認証
HSCODE8504409999
USHSCODE8504409580
UPC
EUHSCODE8504409590
COOCHINA
部品リスト
SenseCAP T1000-E Charging Puck
x1
SenseCAP T1000 Magnetic USB Type-A to 4Pin Charging Cable
x1
SKU 110992184
It’s a minimalist charging puck designed for T1000-E Tracker’s daily use. Securely mounts in any orientation (even upside down) via screws or adhesive, with hidden cable routing for clutter-free setups on desks, walls, or workspaces. Compatible only with T1000-E models.The product is a co-create collaboration with Seeed Studio and Jace Harrison Crowley.
JPY¥2359.00
