製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Featuring SSD202 SoC (Arm® Cortex®-A7 Core) with 128MB DDR3 RAM and 2GB NAND Flash
  • Ultra-small size (29.5mm*29.5mm) with a single-sided layout, fully shielded on the back, and optional shielding cover on the front
  • Supports Linux OS with super-fast boot-up times
  • Integrates 1 way 10/100M Ethernet PHY and 2.4GHz Wi-Fi for network connectivity
  • 96-pin package with 1.1mm pitch extending all resources of SSD202 to connect to other peripherals
IDO-SOM2D02-V1-2GW is an ultra-small SoM (System on Module) based on SigmaStar SSD202 SoC (Arm® Cortex®-A7 Core) with 128MB DDR3 RAM and 2GB NAND Flash. The module integrates Ethernet, Wi-Fi, USB, audio, IR receiving interface, display interface, power management circuits, and other peripherals on a 2.95cm x 2.95cm PCB.
This SoM has a single-sided layout which means the back of the PCB is completely flat and has no traces. This helps to get rid of any interference when using this board with a carrier board. It can run Linux OS and has fast boot-up times with the included NAND flash storage. IDO-SOM2D02-V1-2GW has a 96-pin package with a 1.1mm pitch extending all resources of SSD202 to connect to other peripherals and prototype your projects!
Specifications
SpecificationDetails
CPUSigmaStar SSD202
Arm® Cortex®-A7 dual-core processor, up to 1.2GHz
Video processorSupports max. resolution FHD (1920x1080)/60fps decoding, H.265/HEVC Decoder, I/P/B slices, all Intra-prediction modes, all inter-prediction modes
RAM128MB DDR3 memory
Supports auto-refresh and self-refresh mode
Storage2GB SPI Flash
SystemLinux
EthernetSupports two Ethernet ports, supports 10/100Mbps half/full duplex, one
built-in 10/100M Ethernet PHY, supports one RMII to connect external PHY
WiFIEquipped with Sigmaster WiFi chip (SSW101B), with high performance, and 500 meters transmission distance in open space
DisplaySupports MIPI/RGB interface
MIPI TX DSI 4-lane with max, 1.5Gbps, and output up to FHD 60fps
Supports FHD graphic layer with Index
4/8,ARGB1555/ARGB4444/ARGB8888,RGB565,and YUV422 format
Audio1 x Mono AMIC
1 x Dual channel DMIC
1 x LINEOUTR/L, supports 8K/16K/32K/48KHz Sampling Rate
USB1 x USB 2.0 HOST
Infrared1 x Infrared receiving interface (PM_IRIN)
Peripherals4 x UART(PM_UART is used as Debug Serial by default)
1 x SDIO2.0 (Data bus 1/4 bit mode, compatible with SD Specification 2.0)
2 x I2C, 1 x I2S, 1 x SPI, 4 x PWM, several GPIOs
Dimensions29.5mm x 29.5mm
Interface TypeStamp hole(96 PIN, 1.1mm pin pitch)
PCB1.2mm thickness, 4-layer board, high Tg material, immersion gold process
Weight8g
Applications
  • Smart displays
  • Building intercom indoor units
  • Medical electronics
  • Voice recognition
  • Smart home
  • IoT smart gateways
1 x IDO-SOM2D02-V1-2GW SoM based on SSD202 SoC
ドキュメント
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
IDO-SOM2D02-V1-2GW SoM based on SSD202 SoC - 128MB DDR3 RAM and 2GB SPI Flash
SKU 102110558
JPY¥2375.00
廃番
