おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Key Features
  • A compact robot controller board with all the RP2040 goodness
  • Controls 4x Servo motors
  • Drives 2x DC motors with quick test buttons
  • Built-in LiPo charger
  • Auto power selection: USB 5V, LiPo (1-cell) or Vin (3.6-6v)
  • Power on/off switch
  • 7x Grove ports
  • LEDs on 13x IO pin
  • 2x RGB LEDs (Neopixel)
  • Piezo buzzer with mute switch
  • 2x push button
The Maker Pi RP2040 features the first microcontroller designed by Raspberry Pi - the RP2040 - embedded on a robot controller board! The board comes with a 2-channel DC motor driver, 4 servo motor ports, 7 Grove I/O connectors, and lots of LEDs for troubleshooting and visual effects.
The DC motor driver on board is able to control two brushed DC motors or a single bipolar/unipolar stepper motor. The built-in Quick Test buttons and motor output LEDs allow a functional test of the motor driver in a quick and convenient way without the need of writing any test code. The board features push buttons ready to detect your touch. In addition, the board also can be used to play tone or melody with Piezo Buzzer! Sure, you can use Buzzer Mute Switch to mute the piezo buzzer.
All the designs can provide developers with a better experience in DIY robot/motion control projects.
The board is compatible with the existing Pico ecosystem, Software, firmware, libraries and resources that are developed for Pico should work seamlessly with Cytron Maker Pi RP2040 too. CircuitPython is preloaded on the Maker Pi RP2040, so it’s very easy to get started. The board supports commonly programming languages as well, so you are free to use MicroPython and C/C++ for Pico/RP2040.
NoParametersMinMaxUnit
1Power Input Voltage (USB, LiPo or VIN) *3.66V
2Digital Input VoltageLow Level-0.30.8V
High Level2.03.6V
3Digital Output VoltageLow Level00.5V
High Level2.63.3V
4Analog Input Voltage03.3V
5Vmotor (Only USB is connected) *VUSB - 0.4V
6Vmotor (Only either one of LiPo or VIN is connected) *VLiPo or VINV
7Vmotor (USB and LiPo are connected) *VUSB - 0.4V
8Vmotor (USB and VIN are connected) *VIN < VUSBVUSB - 0.4V
VIN > VUSB
and
VIN - VUSB < 0.6
VIN - 0.4V
VIN - VUSB > 0.6VINV
9Maximum DC Motor Current Continuous-1A
Peak (< 5 seconds)-1.5A
10Operating Temperature-2085℃
Board layout & Function
Dimension
認証
HSCODE8538900000
USHSCODE8538901000
UPC
EUHSCODE8543709099
COOMalaysia
MAKER PI RP2040
SKU 102991562
The Maker Pi RP2040 features the first microcontroller designed by Raspberry Pi - the RP2040 - embedded on a robot controller board! The board is a perfect choice for DIY robot/motion control projects.
JPY¥1567.00
廃番
product.detail.alsoAdd.title
