DeskPi Super6C Raspberry Pi CM4 Cluster Board is a standard mini-ITX motherboard, supporting up to 6 Raspberry CM4, equipped with storage expansion function for each one, mounted rich PC case front panel headers, powered by DC or ATX power supply. This board can be a great opportunity for you to learn cluster applications or distributed Machine Learning computing, under the vast and interesting ecosystems of Linux, cloud-native and Raspberry Pi.
The DeskPi Super6C Raspberry Pi CM4 Cluster Board is a standard mini-ITX motherboard, capable of assembling up to 6 Raspberry CM4 compute modules, where each module has enhanced peripheral equipment for advanced functions, including storage expansion. It comes with rich PC case front panel headers and offers two power supply options for the users. This board can be a great opportunity for you to learn cluster applications or distributed Machine Learning computing, under the vast and interesting ecosystems of Linux, cloud-native and Raspberry Pi.
Uniting 6 independent Raspberry Compute Modules (nodes) in one cluster board, you can program to make these cluster nodes interoperate, for managing resources in Linux, building your own cloud service. In turn, you can also assemble all these cluster nodes’ resources to make one superior server (or supercomputer), for reaching even more advanced performance and deploying it in the edge computing scenarios like embedded Machine Learning. The nodes onboard communicate with each other through the onboard 1 Gbps switch and each node gets its own IP address.
For every module on the board, there has been placed several peripheral interfaces for enhanced functions, including one Micro USB 2.0 connector, an M.2 slot, a TF card slot along with 5V fan interface. As for the primary computing module, there are two additional USB Host A 2.0 interfaces and two USB Host 2.54 4-pins for host usage and two HDMI interfaces (HDMI 2.0 and HDI 1.4a) for the multiple displays. The board also comes with two 1Gbps RJ45 network interfaces, three 12V fan interfaces, an on/off switch, and one reset button. And there are two power supply options which support by both 19V~24V DC and 12V ATX.
This is your Raspberry Pi cluster. You can use it to handle a MySQL or Postgres database, to install an Apache server; to program and manage resources in Linux; to do scripting in BASH, Python, and other scripting languages to make those cluster nodes interoperate. You can use it to make and manage your own cloud service.
This is your Raspberry Pi cluster. You can use it to learn Docker, Kubernetes, Serverless, to turn all the cluster nodes’ resources into one supercomputer with the help of simultaneous processing software like OpenMPI.
If you are interested about the cluster board, Seeed has provided the ones for Jetson Nano Module and Jetson NX Module:
If you care more about instruments powered by Raspberry Pi CM4 Compute Module, Seeed provides you:
Parameter | Value |
SoM Interfaces | Support up to 6 Raspberry Pi CM4(with or without eMMC version) |
Storage Expansion | 1x M.2 2280 slot and 1x TF card slot for each CM4 (6 total) |
Display | One HDMI 2.0, One HDMI 1.4a (Connect to Primary CM4) |
USB Interface | 2x USB-A 2.0, 2x Host 2.54 Pins(Connect to Primary CM4); 1x Micro USB 2.0 for each CM4 |
Fan Interface | 1x 5V FAN Header for each CM4; 3x 12V FAN Header additional |
Network Ports | 2x 1 Gbps RJ45 ports |
Power Supply | 19V~24V / 100W DC; 12V ATX power supply 500 W power |
Dimensions | 170mm x 170mm x 21mm(Mini-ITX) |
For a more specific diagram of rich interface connectors, please refer to here.
Raspberry Pi CM4 Cluster Mini-ITX Board | x1 |
89.87W Power Supply | x1 |
DeskPi Super6C supports all Raspberry Pi CM4 with and without eMMC.
You can boot the OS either from eMMC, SD Card or netboot.
Yes, you can flash a compute module using a Micro USB cable.
There are 2 USB-A and 2 USB 2.54 Pins on the board. They only connect to CM4 1$. The two HDMI ports are also the same.
NIC – There is an 8-port gigabit switch on the board. Each port goes to each node plus one uplink. Two RJ45 out are from the switch. You can use them to connect to other network devices without an extern switch.
Yes.
Note
This product is shipped with a US plug by default.
DeskPi Super6C Raspberry Pi CM4 Cluster Board is a standard mini-ITX motherboard, supporting up to 6 Raspberry CM4, equipped with storage expansion function, mounted rich PC case front panel headers, powered by DC or ATX power supply. This board can be a great opportunity for you to learn cluster applications or distributed Machine Learning computing, under the vast and interesting ecosystems of Linux, cloud-native and Raspberry Pi.
