製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
The Raspberry Pi Pico 2W is the wireless version of the Raspberry Pi Pico 2, which builds upon the Pico 2 itself and provides 2.4GHz 802.11n Wi-Fi and Bluetooth 5.2 functionality.
  • High-Performance Chip: High-performance RP2350 microcontroller with a clock speed of up to 150MHz
  • Wireless Connection Supported: Incorporate Wi-Fi IEEE 802.11n wireless LAN, Soft access point supporting up to four clients, as well as Bluetooth 5.2 connection.
  • Double Memory: Doubled on-board SRAM capacity, reaching 520KB
  • Double Storage: Doubled on-board Flash storage capacity, reaching 4MB
  • Dual-Core Architecture: Choose between the more powerful Arm Cortex-M33 cores or open-source RISC-V Hazard3 cores
  • Enhanced Security: Comprehensive security architecture, supporting secure boot, hardware encryption, and more
  • Easy to Develop: Supports C/C++ and Python programming, lowering the development barrier
  • Backward Compatible: Hardware and software compatible with the Raspberry Pi Pico 1
仕様
Parameter
Form factor
21 mm × 51 mm
CPU
Dual Arm Cortex-M33 or dual RISC-V Hazard3 processors @ 150MHz
Memory
520 KB on-chip SRAM; 4 MB on-board QSPI flash
Connectivity
2.4GHz 802.11n wireless LAN and Bluetooth 5.2
Interfacing
26 multi-purpose GPIO pins, including 4 that can be used for ADC
Peripherals
2 × UART
2 × SPI controllers
2 × I2C controllers
24 × PWM channels
1 × USB 1.1 controller and PHY, with host and device support
12 × PIO state machines
Input power
1.8–5.5V DC
Operating temperature
-20°C to +85°C
Supported input power
1.8–5.5V DC
On-chip resources
Accelerated floating point libraries on-chip
ハードウェア概要
Pinout
用途
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8471707000
COOUNITED KINGDOM
部品リスト
Raspberry Pi Pico 2 W
x1
Raspberry pi pico 2 W - Raspberry Pi RP2350 chip
SKU 102111018
Raspberry Pi Pico 2 is a newly launched microcontroller board from Raspberry Pi, based on the new high-performance, secure RP2350 microcontroller.
Raspberry Pi Pico 2 W adds on-board single-band 2.4GHz wireless interfaces (802.11n) using the Infineon CYW43439 to the Pico 2 hardware, providing Wi-Fi & Bluetooth wireless connectivity.
JPY¥1108.00
お問い合わせ
最小発注数量:1200個
