おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
Raspberry Pi Pico H is a version with pre-soldered male headers on all through-holes and a 3-pin debug connector. The pitch remains 2.54mm and is breadboard compatible.
  • Fast Development and Debugging: Raspberry Pi Pico H features pre-soldered pins and a 3-pin debug connector.
  • High Performance: Powered by RP2040 dual-core ARM Cortex M0+ processor, running up to 133 MHz, included 2MB of onboard Flash memory, mounted 25 multi-function GPIOs
  • Easy Development: Drag & drop programming over a USB through MicroPython & Arduino
  • Design for Beginners/Children: Provide tons of projects and tutorials, allowing for quick positive programming feedback, getting started well with electronics
  • Suitable for Embedded AI: Great Embedded Machine Learning platform by two cores of RP2040 chip and plenty of on-chip RAM, while also supporting TensorFlow Lite
  • Grove Starter Kit for Raspberry Pi Pico Series: The Grove Starter Kit for Raspberry Pi Pico offers a variety of components and MicroPython courses to help you easily get started.
仕様
Parameter
CPU
Dual-core ARM Cortex M0+ processor, flexible clock running up to 133 MHz
Storage
264kB of SRAM, and 2MB of on-board Flash memory
GPIO pins
26 multifunction GPIO pins, including 3 analogue inputs
Interface
2× SPI, 2× I2C, 2× UART, 3× 12-bit ADC, 16× controllable PWM channels
Power supply & Downloading interface
USB Type-C interface
Dimemsions
21 mm × 51 mm form factor
Operating temperature
-20°C to +85°C (Raspberry Pi Pico and Pico H); -20°C to +70°C (Raspberry Pi Pico W and Pico WH)
Supported input power
1.8–5.5V DC
On-chip resources
Accelerated floating point libraries on-chip
ハードウェア概要
Pinout
用途
認証
HSCODE8471504090
USHSCODE8473309100
UPC
EUHSCODE8471800000
COOJapan
部品リスト
Raspberry Pi Picox1
Raspberry Pi Pico H
SKU 102111002
Raspberry Pi Pico is equipped with the powerful RP2040 chip, features high performance and rich on-board interfaces/resouces, yet offered a relatively low price. It is perfectly designed for the beginners to electronics, pretty suitable for IoT controlling applications.
USD$5.00
廃番
product.detail.alsoAdd.title
