おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High Performance: Powered by RP2040 dual-core ARM Cortex M0+ processor, running up to 133 MHz, included 2MB of onboard Flash memory, mounted 25 multi-function GPIOs
  • Easy Development: Drag & drop programming over a USB through MicroPython & Arduino
  • Design for Beginners/Children: Provide tons of projects and tutorials, allowing for quick positive programming feedback, getting started well with electronics
  • Suitable for Embedded AI: Great Embedded Machine Learning platform by two cores of RP2040 chip and plenty of on-chip RAM, while also supporting TensorFlow Lite
  • Grove Starter Kit for Raspberry Pi Pico: The Grove Starter Kit for Raspberry Pi Pico offers a variety of components and MicroPython courses to help you easily get started.
仕様
Parameter
CPU
Dual-core ARM Cortex M0+ processor, flexible clock running up to 133 MHz
Storage
264kB of SRAM, and 2MB of on-board Flash memory
GPIO pins
26 multifunction GPIO pins, including 3 analogue inputs
Interface
2× SPI, 2× I2C, 2× UART, 3× 12-bit ADC, 16× controllable PWM channels
Power supply & Downloading interface
USB Type-C interface
Dimemsions
21 mm × 51 mm form factor
Operating temperature
-20°C to +85°C (Raspberry Pi Pico and Pico H); -20°C to +70°C (Raspberry Pi Pico W and Pico WH)
Supported input power
1.8–5.5V DC
On-chip resources
Accelerated floating point libraries on-chip
ハードウェア概要
Pinout
用途
認証
HSCODE8517180050
USHSCODE8473309100
UPC
EUHSCODE8471800000
COOJapan
部品リスト
Raspberry Pi Pico
x1
A: Raspberry Pi Pico is powered by the RP2040 dual-core Cortex-M0+ microcontroller, offering low power consumption, compact size, and cost efficiency for IoT applications. It provides a rich set of GPIOs and supports common interfaces such as UART, I²C, and SPI, making it easy to connect sensors and actuators. Combined with modular ecosystems like Grove, Pico enables rapid prototyping of low-power and real-time IoT devices.
Raspberry Pi Pico
SKU 102110537
Raspberry Pi Picoは、Raspberry PiRP2040マイクロコントローラーチップをベースにしたマイクロコントローラーボードです。 デュアルコアARMCortex M0 +プロセッサを搭載しています。
JPY¥697.00
廃番
product.detail.alsoAdd.title
