おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Compact size (69mmx41.5mmx31.5mm (L*W*H))
  • Medium range detection (up to 40m)
  • Adjustable frame rate with a maximum of 1KHz
  • Multiple configurable baud rates
  • Communication using CAN interface
  • Wide range of input voltages (7-30V) with reverse protection
  • PC/ABS/PMMA enclosure with IP65 water and dust resistance for industrial applications
TF02-i LiDAR is an industrial-grade medium-range distance sensor. Its maximum detection range can reach up to 40m and it has an adjustable frame rate with a maximum of 1KHz. It has a PC/ABS/PMMA enclosure with IP65 water and dust resistance. It supports a wide range of input voltages (7-30V) with reverse protection to protect the internal circuit. Multiple built-in operating modes are included for the users to change their parameters and configurations to meet different applications.
How Does It Work?
TF02-i is a single point LiDAR, which is based on Pulse Time of Flight (PTOF). It adopts an incoherent energy receiving mode, and the detection is mainly based on Pulse counting. TF02-i emits a narrow pulse laser, which is collimated by the transmitting lens to form a collimated light, which enters the receiving system after being reflected by the measured target and is focused on the APD detector by the receiving lens. The time between the transmitted signal and the received signal is calculated through the circuit amplification and filtering, and the distance between TF02-i and the measured target can be calculated through the speed of light.
Specifications
ParametersDetails
Product
Performance
Operating Range0.1-40m@90% reflectivity
0.1-13.5m@10% reflectivity
0.1-40m@90% reflectivity&100Klux
0.1-13.5m@10% reflectivity&100Klux
Accuracy±5cm (0.1~5m), 1% (5~40m)
Distance resolution1cm
Frame rate1Hz~1000Hz adjustable (default 100Hz)
Repeatability1σ:<2cm(0.1~35m@90% reflectivity)
Ambient light immunity100Klux
Operating temperature-20~60℃
Optical
Parameters
Light sourceVCSEL
Central wavelength850nm
Photobiological safetyClass1 (EN60825)
FOV (Field of view)3°
Electrical
Parameters
Supply voltage7~30V
Average current≤70mA@12V
Power consumption≤0.85W@12V
peak current100mA
Communication interface
level
LVTTL(3.3V)
Communication interfaceCAN
OthersEnclosure ratingIP65
Enclosure materialPC/ABS/PMMA
Dimensions69mmx41.5mmx31.5mm(L*W*H)
Storage temperature-30~80℃
WeightWeight 60g(with cable)
Cable length70cm
Applications
  • Vehicle collision avoidance and safety warning systems
  • Traffic flow statistics
  • Camera trigger
  • UAV assisted takeoff and landing
  • 1 x TF02-i LiDAR - Distance Sensor (40m) with CAN Interface
認証
HSCODE9031900090
USHSCODE9031902100
UPC
EUHSCODE9013101000
COOCHINA
SKU 101090021
JPY¥20418.00
product.detail.alsoAdd.title
