製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Full-speed USB device interface compatible with USB V2.0
  • Supports baud rates from 50bps to 1Mbps
  • Switchable 5V and 3.3V UART serial port signal levels
  • Compatible with 32/64-bit Windows operating systems including Windows 10, 8.1, 8, 7, Vista, XP, and various server editions
  • Microsoft digital signature certification for secure operation
  • Allows for control of SMS and SCS series servos through a single serial port
  • Asynchronous half-duplex communication mode with hardware automatic diversion, reducing the need for additional IO control
  • Error-proof connection interface for servo systems to ensure proper connections
  • General-purpose UART interface that can be used for USB-to-serial output or to connect MCU UART for controlling servos
  • Equipped with signal level power indicator (D1), TX (D2), and RX (D3) indicators for easy data status monitoring
  • 5V voltage supplied from USB; external 5V supply can also be used
  • 500mA overcurrent protection and overvoltage protection for the USB power supply
仕様
Product
Feetech HL-3615-C002 6V 2.5Kg Servo
Weight
12.5 g
Dimensions
55.8 * 36.6 * 11.5 mm
Mounting size
48.8 * 28.8 mm
USB interface
Mini USB
UART interface
2.54 pin spacing
SCS servo interface
3PIN 5264-3AW
SMS servo interface
4PIN 5264-4AW
Actuator power interface
5.08 terminal
ハードウェア概要
ドキュメント
認証
HSCODE8503001000
USHSCODE8501106080
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
FE-URT-1 USB to TTL, 485 bus programmer
x1
Feetech FE-URT-1 USB to TTL, 485 bus programmer
SKU 100036057
The FE-URT-1 is a multifunctional serial port signal converter designed to simplify the debugging and operation of FEETECH SMS and SCS series serial servos. This device seamlessly integrates a USB-to-serial chip with a linear low-dropout voltage regulator circuit, facilitating the conversion of USB signals to 5V or 3.3V serial signal levels, which are compatible with a wide range of servos.
JPY¥1583.00
