製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
【Note】
  • From China warehouse to the United States, choose "US Direct Group Shipping" to enjoy duty-free!
  • High Precison Provides 360-degree positioning with precise angle control and multi-turn continuous rotation capability
  • Metal Gearbox Includes 1:345 gear reduction ratio metal gearbox
  • Easy Calibration Offers one-touch midpoint calibration
  • Rich output Provides real-time feedback of position, speed, voltage, current, temperature, and load
  • 12V Servo Could be used with 12V power supply
仕様
Product
Feetech ST3215 C047
Voltage
4- 14V
Operating Temperature
-10℃~60℃
Mechanical Dimension
45.2mm x 24.7mm x 35mm
Communication Interface
Serial
ハードウェア概要
用途
認証
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
ST3215-C047 Servo
x1
Servo Horn
x2
Screw
x18
JST Wire
x1
Feetech ST3215-C047 12V 30Kg Servo
SKU 108090003
STS3215 C047 is a 12V 30Kg. cm serial bus smart servo, with plastic case, core motor, 1:345 metal gearbox and 12 bit high precision magnetic coding sensor. The stall toruqe is 30 kg. cm and the rated torque is 10kg.cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications, such as LeRobot SO-Arm 101.
JPY¥3483.00
