製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High Torque and Low-Speed Performance: Delivers high stall torque (14.2kg.cm @ 12V) and low no-load speed (100RPM), suitable for high-torque applications.
  • High-precision Control: Equipped with a 12-bit magnetic encoder for 360° absolute position control with 0.088° resolution, supporting multiple operating modes and multi-turn functionality.
  • Feedback: Provides comprehensive feedback on load, position, speed, input voltage, current, and temperature.
  • Electronic Protection: Features customizable overload protection, overvoltage protection (4V to 14V range), and overheat protection (shuts down at >80℃).
  • Robust Electronic Protection Functions: Ensures reliable operation with customizable overload settings, overvoltage protection, and overheat shutdown.
仕様
Product
Feetech HL-3915-C001 12V 14.2Kg Servo
Dimensions
20×34×23 mm
Weight
35.8±2 g
Voltage Range
4V-14V
Operating Voltage
12V
No-Load Speed
0.1 sec/60° (100RPM)
Stall Torque
14.2kg.cm
Rated Load
4.5kg.cm
Operating Temperature
-10℃~60℃
ハードウェア概要
認証
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
HL-3915-C001
x1
M2*4
x8
15cm -1.25mm to 5264 terminal wire
x1
20cm -1.25mm terminal wire
x1
SKU 100042780
It's a high-torque servo motor, delivering 14.2 kg.cm of torque at 12V and featuring a precise 1/320 gear ratio. It is perfectly suited for small robotics, robot arms, and low-torque drive applications where powerful and accurate control is paramount. With a rated speed of 100 RPM, this servo ensures efficient performance in dynamic applications.
JPY¥6331.00
