x1
おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Achieving a truly responsive home requires more than just gadgets; it requires a synchronized ecosystem. This curated selection of hardware is engineered to function as a single, cohesive "body" of intelligence—processing every automation locally for maximum speed and privacy.
  • The Brain (Home Assistant Green): The centralized hub responsible for all logic and data decisions.
  • The Face (reTerminal E1002): An ambient, glare-free dashboard responsible for distraction-free information interaction.
  • The Nervous System (MR60BHA2 mmWave & Soil Sensor): High-precision nodes responsible for all-around environmental and physiological sensing.
  • The Hands (XIAO Smart IR Mate & W5500 Ethernet Adapter): The executive bridge responsible for bringing traditional IR appliances and BLE devices into your Home Assistant ecosystem.
Why Home Assistant Redefining the Soul of Your Home? Ever felt like your "smart" home is just a collection of disconnected apps? Home Assistant changes the game by moving the brain of your home from the cloud to your living room. It's no longer about opening an app to toggle a switch; it's about a home that anticipates your needs and acts on your behalf.
Looking for more options? Explore the more Home Assistant compatible devices: we offer a diverse range of compatible hardware, giving you the freedom to pick and choose the exact components that fit your unique home layout.
Can't Find the Perfect Device? Build Your Own: Sometimes, off-the-shelf products just don't fit your specific needs. Why not follow the community's lead and DIY your own? Our scenario-specific DIY Kits turn complex hardware into simple "building blocks." You can rapidly prototype and deploy custom devices—tailored to the exact requirements of your space—as easily as snapping modules together.
To make this shift practical, Home Assistant does not exist as a single device, but as a system architecture that can be distributed across dedicated hardware roles. Instead of relying on one monolithic controller, intelligence is split into perception, decision-making, visualization, and execution—each handled by purpose-built components that work together locally in real time:
1. The Heart of Privacy: Plug-and-Play Hub
Experience a stable, cloud-independent smart home from the moment of unboxing. As the centralized "brain" of the ecosystem, Home Assistant Green runs entirely on local hardware—ensuring 100% data privacy and lightning-fast response times. No subscriptions, no hidden fees, and no complex flashing required; it’s the definitive foundation for a secure, professional-grade sanctuary.
2. A Dashboard: The "Face" of Your Home
Move beyond the clutter of phone apps. The reTerminal E serves as a physical interface for your data, visualizing real-time energy, climate, and other information in one place—naturally blending into your living space.
3. Presence Sensor: Sensing Beyond Motion
Stop being "left in the dark." Unlike traditional sensors, this 60GHz technology detects micro-movements like breathing. Your home knows you’re there even when you're perfectly still, keeping lights and climate active while you read or sleep.
4. Living Ecosystem: Real-time Plant Intelligence
Bring your greenery into the ecosystem. Receive instant alerts on your ePaper display the moment your plants need attention, turning manual plant care into a seamless, automated part of your daily routine.
5. Connectivity Bridge: Universal Device Integration
Seamlessly bridge the gap between legacy hardware and modern automation. By combining high-performance IR control with a rock-solid Ethernet Bluetooth Proxy, you can bring traditional ACs, TVs, and BLE sensors into your local loop. Pair it with mmWave sensors to orchestrate a truly responsive home—automatically manage the environment and power the moment you leave the room.
仕様
Processor
Quad-core Cortex-A55 CPU up to 1.8GHz
RAM
4 GB RAM
Storage
32 GB eMMC
Expansion Slot
SD card slot for recovery purposes only
Ethernet
Gigabit Ethernet
USB Ports
2 x USB 2.0 Type-A host port
Display
1x HDMI for debugging purposes only
Wireless Protocols
Zigbee 3.0 and Matter(with Home Assistant SkyConnect)
Pre-installed Firmware
Home Assistant OS
Power
12 V / 1 A through barrel DC power jack(barrel connector)
LEDs
White (Power), Green (Activity Indicator), Yellow (Home Assistant system state)
Power off Button
Press and hold for 6 seconds to shut down safely,
Press and hold for 12 seconds to force the power off
Enclosure
Large aluminum heatsink, great heat dissipation
Size
111*111*33.6mm
Operating Temperature
0 ~ 40℃
用途
Rapid Deployment for Whole-Home Automation
1.Rapid Setup: From Unboxing to First Scene
2.Ecosystem Synergy: Seamless Whole-Home Integration and Automation
3.Absolute Sovereignty: Local-First Privacy
部品リスト
x1
reTerminal E1002 Full-color ePaper Display
x1
XIAO 60GHz mmWave Human Breathing and Heartbeat Sensor -MR60BHA2
x1
Everything Presence Lite
x1
XIAO Soil Moisture Sensor
x1
XIAO Smart IR Mate
x1
Not necessarily. But if you already have those devices, adding one is highly recommended. While this kit works perfectly over Wi-Fi out of the box, we offer the HA Connect ZBT-2 (Zigbee) and ZWA-2 (Z-Wave) as optional upgrades. Simply plug them into your Home Assistant Green to instantly transform it into a universal hub, allowing you to sync thousands of third-party Zigbee or Z-Wave sensors and switches into your local, private ecosystem.
Ambient & Zero-Distraction. Unlike glowing LCD screens that are harsh at night, this full-color ePaper display is completely backlight-free, mimicking the look of real paper. It consumes near-zero power to maintain an image, providing a glare-free, always-on dashboard that blends naturally into your home decor. It’s the perfect way to monitor your home status without adding another intrusive "gadget" to your living space.
Yes, as long as they are infrared-controlled. The XIAO Smart IR Mate acts as a universal bridge for legacy devices with an IR receiver—like air conditioners, TVs, and fans. By pairing it with our presence sensors, Home Assistant can automatically turn off your AC the moment a room becomes vacant, bringing your "dumb" appliances into a modern, automated ecosystem.
Human Presence vs. Simple Motion. Standard PIR sensors often turn the lights off if you sit still while reading or sleeping. The 60GHz mmWave technology in this kit is sensitive enough to detect the micro-movements of human breathing and heartbeats. This ensures your home knows you are there even when you are perfectly still, preventing "false offs."
Instant Discovery via Pre-Configured ESPHome. We’ve taken the complexity out of hardware integration. All interactive devices and sensing nodes in this kit come pre-installed with ESPHome firmware. The moment you connect them to your network, they are automatically discovered by Home Assistant as native entities. There is no need for manual coding or complex configuration—simply click "Configure" in your HA dashboard, and your sensors, displays, and voice assistants are ready to trigger automation scenes instantly. This native synergy ensures a stable, low-latency connection that works 100% locally.
Absolutely! While Home Assistant is known for its limitless power, the learning curve can be steep for beginners. We created this bundle specifically to solve that. By providing pre-configured, industrial-grade hardware, we’ve eliminated the most frustrating steps: image flashing, driver debugging, and manual terminal commands.
[Up to 12% Discount] Home Assistant Starter Kit – Plug & Play Smart Home Development
SKU E2026041501
Building a professional smart home should not be an overwhelming puzzle of fragmented options and complex configurations. Designed to lower the barrier for anyone seeking local control, this curated bundle combines Home Assistant Green with the most essential daily devices. By pre-integrating high-performance hardware, the setup process is simplified—eliminating the frustration of manual driver debugging. From intelligent gateways and ambient displays to various sensors, this kit provides a ready-to-use foundation for a responsive, private, and fully automated sanctuary in minutes.
12% off is automatically applied at checkout.
JPY¥53428.00
Home Assistant Greenx1¥31481.00
XIAO 60GHz mmWave Human Breathing and Heartbeat Sensor -MR60BHA2x1¥3832.00
XIAO Soil Moisture Sensorx1¥1726.00
reTerminal E1002 Full-color ePaper Displayx1¥16389.00
product.detail.alsoAdd.title
