製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
ESPHome Ready-Made Project: Zero-Code Setup!
Seeed Studio is proud to have joined the ESPHome Ready-Made Project. No YAML or coding required—flash your firmware directly via web browser for instant integration.
Featured Devices:
Experience seamless setup now at the ESPHome Ready-Made Projects website!
Explore landing page to discover more plug-and-play, Home Assistant–compatible devices designed for faster deployment and simplified integration.
  • Seamless Integration with Home Assistant
Powered by XIAO ESP32-C3, built on the ESPHome platform, XIAO Smart IR Mate is automatically discovered by Home Assistant, offering simple entities for effortless automation and scripting.
  • Intuitive Physical Interaction Feedback
Features a touch module, vibration motor and LED indicator. It vibrates once is touched, After learning the IR signal, touch it to send the signal . Short vibrations confirm actions, long vibrations signal learning mode, and the LED indicates network status, simplifying setup and troubleshooting.
  • Easily IR signal Learning
Supports learning up to 10 IR commands from standard IR remotes for one-tap playback in Home Assistant.
  • Compact Design, USB-C Powered
Measuring just 65mm in diameter and 19mm in height, the XIAO IR Mate features an ultra-compact design. It is conveniently powered via a USB-C connection, eliminating the need for bulky external adapters.
Note:
Early Build provides beta products (featuring 3D-printed cases) and evolving software before final release. We welcome your feedback and suggestions to shape the product's evolution. Enjoy exploring!
仕様
Item
Details
Main Controller
Seeed Studio XIAO ESP32-C3
Wireless Connectivity
Wi-Fi 2.4GHz & BLE (Available for custom development)
Power Supply
5V, via XIAO ESP32-C3's USB Type-C
IR Transmission
3x High-power IR LEDs for 360° coverage
IR Reception
1x High-sensitivity IR receiver
Onboard Interfaces
  • Touch Sensor
  • Vibration Motor
  • Status Indicator Light
  • Reset Button
Software
Pre-flashed ESPHome firmware, with native Home Assistant support
Dimensions
Diameter: 65mm
Height: 19mm
ハードウェア概要
用途
  • Unified Smart Home Control
  • Advanced Automation Scenes
  • Energy-Saving Automation
  • Voice Control for Traditional Appliances
  • DIY Electronics Projects
認証
HSCODE8536500090
USHSCODE8536509020
UPC
EUHSCODE8536301090
COOCHINA
部品リスト
XIAO IR Mate
x1
XIAO Smart IR Mate: Smart Wi-Fi Infrared Proxy for Home Assistant (ESPHome Ready-Made Project)
SKU 109990586
The XIAO IR Mate is a compact yet powerful smart infrared remote control hub designed specifically for Home Assistant. With the XIAO ESP32-C3 at its core, it seamlessly integrates with Home Assistant, allowing you to directly control your traditional infrared home appliances, such as TVs, air conditioners, and fans, via your mobile phone or automation routines. Featuring one-touch learning, and haptic feedback, it's the ultimate tool for making your traditional devices smart.
JPY¥1726.00
