製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Perfect for home assistance: Support smart home platforms like Home Assistant, openHAB, Zigbee2MQTT, loBroker, Domoticz Zigbee Plugin, Jeedom Zigbee Plugin
  • High communication quality: SMA interface for the external rotatable antenna, +20dBm output gain, further signal reach
  • Support various platforms: Linux, Ubuntu, Raspbian, Windows, macOS (Windows and macOS require corresponding driver installation)
  • Powerful MCU: EFR32MG21 is a 2.4 GHz wireless SoC optimized for line-powered ZigBee, Thread, and Bluetooth mesh networking applications, including connected lighting, gateways, voice assistants, and smart Electricity meter
  • Certification: CE/FCC/RoHS
Zigbee 3.0 USB Dongle Plus–ZBDongle-Es is a universal Zigbee USB stick. It can be directly plugged into your computer or Raspberry Pi and can be used as a Zigbee gateway in Home Assistant, openHAB, Zigbee2MQTT, or other open-source platforms to locally control all your Zigbee devices. It supports a wide range of devices, such as switches, temperature and humidity sensors, Wireless door/window sensors, etc, and can manage various sub-devices from various brands or flash router firmware to extend the network range.
It is based on the EFR32MG21 and pre-flashed with the Zigbee coordinator firmware based on EZNet 6.10.3 out of box. It has an SMA interface for an external rotatable antenna with a +20dBm output gain for further signal reach. It supports a working temperature of -10°C~40°C and a working height of ≤2000m, which makes it applicable to use indoors. And the aluminum housing effectively reduces signal interference from peripherals.
You can also develop this on various platforms, such as Linux, Ubuntu, Raspbian, Windows, macOS (Windows and macOS require corresponding driver installation). Click to follow the tutorial on using SONOFF Dongle Plus on Home Assistant.
仕様
MCU
EFR32MG21
Serial Interface Protocol
EmberZNet (EZSP)
USB-Serial Chip
CH9102F
Input
5VDC 100mA Max
Output Power
20dBm(default)
Antenna
External antenna (Manual installation)
Zigbee
Zigbee 3.0(IEEE 802.15.4)
Security
WPA/WPA2
Flow Control
Software flow control
Encryption type
AES-128
Working temperature
-10°C~40°C
Working height
≤2000m
用途
  • Universal Zigbee gateway in Home Assistant
  • Extend the network range
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Zigbee 3.0 USB Dongle Plus–ZBDongle-E×1
Antenna×1
User Manual×1
Sonoff Zigbee 3.0 USB Dongle Plus–ZBDongle-E- Home Assistant Compatible
SKU 113991082
Zigbee 3.0 USB Dongle Plus–ZBDongle-E is a universal Zigbee USB stick. It is based on EFR32MG21 and pre-flashed with the Zigbee coordinator firmware based on EZNet 6.10.3 out of box. It can be used as a Zigbee gateway in Home Assistant, openHAB, Zigbee2MQTT, or other open-source platforms to locally control all your Zigbee devices.
JPY¥3483.00
