製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
Early Build provides beta products (featuring 3D-printed cases) and evolving software before final release. We welcome your feedback and suggestions to shape the product's evolution. Enjoy exploring!
1. Enhance Your Smart Home Setup with 2 Independent Relays
Upgrade your conventional devices with these 2-channel relays, perfect for switching and controlling two separate 100-240V AC appliances. Seamlessly integrated with Home Assistant, enjoy effortless remote control and automation of your home devices.
2. Seamless ESPHome & Home Assistant Compatibility for Intuitive Control
Powered by the XIAO ESP32-C3, this relay ensures smooth integration with Home Assistant through ESPHome. Customize and manage settings directly from the Home Assistant dashboard, providing a user-friendly and centralized control experience.
3. Real-Time and Historical Power Monitoring for Efficient Energy Management
The built-in current meter on the relay allows you to monitor both real-time and historical power consumption of your appliances via the Home Assistant dashboard, helping you optimize energy usage and track consumption patterns.
仕様
AC Rating
100-240V~50/60Hz 10A Max
Max. Load
2400W@240V
Calibration-Free Metering IC
BL0942
Active Energy Measurement Error
0.1%
Dynamic range 4000:1
Realy Channels
2
AC Rating
Wireless
2.4Ghz Wi-Fi
Dimension
58*70*38mm
Enclosure
3D-Printed in White
Open sourced on Thingsverse for custimzation
ハードウェア概要
Terminals
Wires
N
Neutral terminal
Neutral wire
L
Live(100-240 VAC) terminal
Live(100-240 VAC) wire
PE
Protective Earth wire
認証
HSCODE8536490090
USHSCODE8536490050
UPC
EUHSCODE8531202090
COOCHINA
部品リスト
2-Channel Wi-Fi AC Relay with 3D-Printed Enclosure (White)
x1
We are putting the spotlight on Seeed's self-developed Home Assistant-compatible products, offering affiliates 10% commission on referred sales. Sign up to earn more today!
XIAO 2-Channel Wi-Fi AC Relay
SKU 114993526
Upgrade your home with the Dual-Channel AC WiFi Relay, powered by the XIAO ESP32-C3. Seamlessly integrate your existing appliances into the Home Assistant ecosystem, enjoy real-time and historical power monitoring via the built-in current meter, and take full control of your home remotely. Perfect for creating a smarter, more energy-efficient living space.
JPY¥3150.00
