製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Sonoff ZBMINI is a two-way smart switch that supports Zigbee and can use Hands-free Voice Control like Alexa or Hey Google. It can control the switches in your home and make it smarter, which can also connect to many gateways as long as your gateway supports the Zigbee 3.0 protocol.
Feature
  • Support Multiple Gateways: as long as the wireless protocol of the gateway is ZigBee 3.0, it can be connected to ZBMini.
  • Smart and Easy Control: Can realize remote control, and single/ countdown timing.
  • Multiple Control Methods: You can retain both the smart control (app) and the physical switch controlling is still retained. Of course, it is possible to turn on or off the lights upstairs or downstairs.
  • Hands-Free Voice Control: Speak to Alexa or Hey Google, SmartThings, and Alice, and it will perform your command to turn on/off.
  • Miniature size & Easy Installation: Its tiny size allows it to be hidden behind wall switches.
  • Powerful Core IC: Equipped with CC2652P Core is the strongest chip in Zigbee networking produced by TI, with larger rom and more stability.
SONOFF ZBMINI is a two-way smart switch that supports Zigbee and the powerful compatibility ensures with many hubs such as SONOFF ZBBridge, Amazon hub, Samsung SmartThings hub, etc. Because ZBMini uses Zigbee 3.0 protocol, so as long as your gateway uses Zigbee 3.0 protocol Can connect to ZBMini. The Zigbee 3.0 protocol with AES-128 encryption keeps your device data secure and unreadable by prying eyes. ZBMini utilizes a fire-proof and flame-retardant shell to keep your switch safer. When you use multiple Zigbee devices in your home, it can act as a Zigbee router to help transmit Zigbee signals to ensure a stable connection.
SONOFF ZBMINI also supports smart control of furniture. After the ZBMINI is connected to the SONOFF ZBBridge, it can be controlled through the eWeLink APP to realize functions such as remote control, timing, shared control, and smart scene. Suppose you can set up a smart scene for your living room, and use ZBMINI to connect your switches, whether you are going out, or in a different room, you can remotely control the smart switch through your phone. Sonoff BasicR2 also supports Handoff voice control which means you can communicate with Alexa, Google Assistant, and Alice Interact to control other smart furniture in your home.
With the ZBMINI installed behind the home's physical switch and hidden in the switch box, you get a smart light and leave no traces, while the physical switch control is still retained.
Note
It is recommended that the ZBMINI be installed outward from the rear, not inside the metal junction box.
Application
  • Home Assistant
  • Home Automation
  • Smart Home
  • Office
  • Hotel
  • Hospital
Product Type
Zigbee Two-Way Smart Switch
Input
100-240V AC 50/60Hz
Output
100-240V AC 50/60Hz
Zigbee
IEEE 802.15.4 2.4GHz
Max. Load
10A
Material
PC
Certified Compliance
FCC, CE, Zigbee Alliance
Works With
Amazon Alexa, Google Assistant, Samsung Smarthings, Yandex Alice
Sonoff ZBMini
x1
User Manual
×1
認証
HSCODE8536500090
USHSCODE8517620010
UPC
EUHSCODE8536301090
COOCHINA
Sonoff ZBMini-Zigbee3.0-two-way smart switch, Voice control, Smart home
SKU 113991075
JPY¥2373.00
廃番
