製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Tamper Alert: Equipped with tamper-proof features ensures your peace of mind. Receive App notifications on your phone if the sensor is tampered with.
  • Add to Home Assistant: Seamlessly integrates with Zigbee hubs utilizing the Zigbee 3.0 protocol, easily add to Home Assistant for your home automation through ZHA or Zigbee2MQTT
  • Local Scene Intelligent Linkage: Even if your Wi-Fi network crashes, you can still activate Zigbee local scenes as long as your Zigbee devices are powered on. Lower latency, higher reliability.
  • Extended Battery Life: Using CR2477 battery extends the battery life to over 5 years, eliminating concerns about frequent battery replacements.
Support by Platforms
Note: SNZB-04P needs to be used with Zigbee Hub, or with HA Green and Zigbee hub.
仕様
MCU
EFR32MG22
Input
CR2477(3V)
Colour
White
Product dimension
Transmitter(50.5x32x21.9mm)Magnet(27x12x12.4mm)
Net weight
33g
Casing materials
PC
Wireless connection
Zigbee 3.0 IEEE802.15.4
Pairing time
180s
Communication distance
Indoor environment 30m
Applicable place
Indoor
Installation distance
≤20mm
Working temperature
-10°C ~ 60°C
Working humidity
5-95%RH, non-condensing
Working height
Less than 5000m
ハードウェア概要
①Transmitter
②Button
③LED indicator(RED)
④Battery cover
⑤ALignment mark for installation
⑥Magnet
用途
  • Smart Home
  • Front door/Back yard
  • Window
  • Office
  • Prison
認証
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
部品リスト
Transmitter
x1
Magnet
x1
SONOFF SNZB-04P Zigbee Door/Window Sensor - Home Assistant Compatible
SKU 101991403
SNZB-04P is a Zigbee 3.0 protocol-based door/window sensor equipped with a tamper-proof feature, and designed for use with Home Assistant Green and the SkyConnect USB Stick to optimize your smart home comfort.
JPY¥1567.00
廃番
