製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
ESPHome Ready-Made Project: Zero-Code Setup!
Seeed Studio is proud to have joined the ESPHome Ready-Made Project. No YAML or coding required—flash your firmware directly via web browser for instant integration.
Featured Devices:
  • XIAO Smart IR Mate: Your ultimate Home Assistant infrared hub.
  • XIAO W5500 Ethernet Adapter V1.2: Reliable PoE Bluetooth Proxy for Seamless Connectivity.
Experience seamless setup now at the ESPHome Ready-Made Projects website!
Explore landing page to discover more plug-and-play, Home Assistant–compatible devices designed for faster deployment and simplified integration.
  • High-Performance Microcontroller: Built on the XIAO ESP32S3 Plus platform, our board delivers robust processing power and efficient wireless connectivity, making it ideal for complex IoT and embedded applications.
  • Integrated PoE with Isolation & Power Conversion: Featuring a robust PoE module with built-in isolation, the board safely accepts a 12V Ethernet power input. A high-efficiency TPS563201 buck converter then steps the 12V down to a stable 5V rail, providing optimal power to the XIAO ESP32S3 Plus.
  • Reliable Ethernet Connectivity: Equipped with an onboard W5500 Ethernet chip and a standard RJ45 jack, the board ensures stable wired network access for seamless data transmission and remote management.
  • Versatile I/O Options: With dual-sided I/O outputs, you can easily expand functionality and interface with a range of sensors and peripherals to customize your application to exact specifications.
  • Compact & Ready-to-Deploy Design: Combining integrated PoE, isolation circuitry, and Ethernet connectivity in a small form factor, this board simplifies prototyping and enables efficient deployment in smart home, industrial automation, or network appliance projects.
Note:
Early Build provides beta products (featuring 3D-printed cases) and evolving software before final release. We welcome your feedback and suggestions to shape the product's evolution. Enjoy exploring!
This V1.2 features an INT pin wiring fix (D16 → W5500 INTn), enabling active Bluetooth proxy functionality in ESPHome.
仕様
Parameter
MCU
XIAO ESP32-S3 Plus
Antenna
2.4GHz Rod Antenna (2.81dBi)
USB Type-C
Input voltage (Type-C): 5V
PoE Chip
MQ7813T120
PoE Power Supply
PoE IEEE802.3af
Ootput Current: 12V/1.1A
High Efficiency 86% (Input 48V, Load [email protected])
Ethernet Chip
WIZnet W5500
Ethernet Interface
RJ45
10/100Mbps Ethernet
TCP/IP Protocols
TCP, UDP, ICMP, IPv4, ARP, IGMP, PPPoE
LED Indicator
Power x 1
User x 1
Button
Reset
I/O Interface
XIAO ESP32-S3 Plus:
D0/D2/D3/D4/D5/D6/D7/D11/D12/D13/D14/D15/D17/D18/D19
W5500 INTn Pin
D16
Product Size
83 x 118 x 26 mm
Product Weight
75g
Enclosure
3D-Printed in White
ハードウェア概要
Note Change Record
2025/12/1, This V1.2 features an INT pin wiring fix (D16 → W5500 INTn), enabling active Bluetooth proxy functionality in ESPHome.
用途
  • Industrial Automation
  • Network Control
  • Smart Home & Building Automation
  • Remote Monitoring
  • Surveillance
ドキュメント
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
×1
2.4GHz Rod Antenna (2.81dBi) for Seeed Studio XIAO
x 1
XIAO W5500 Ethernet Adapter V1.2 (ESPHome Ready-Made Project)
SKU 113100042
A compact PoE development board featuring the XIAO ESP32S3 Plus, with an integrated, isolated PoE module and TPS563201-based power conversion that delivers a clean 5V supply to power the microcontroller. Ideal for IoT projects, smart home devices, and industrial automation—where a versatile combination of reliable Ethernet connectivity and low-power wireless processing simplifies installation and enhances system performance.
JPY¥3467.00
