製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Powered by XIAO nRF52840 Plus:Works immediately when connected to a compatible ePaper display, with onboard NFC for tap-to-configure, pairing, or triggering content updates.
  • Versatile Display Support: Compatible with a wide range of ePaper screens, supporting both 24-Pin and 50-Pin interfaces with easy switching via jumper caps.
  • BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
  • User-Friendly Buttons: Includes 1 reset button and 3 user-programmable buttons, offering flexibility for project acceleration and customizable functions.
  • Compatible with Various Software Platforms: Whether you prefer coding with Arduino, Platform IO, ESPHome and more, this driver board both approaches, providing maximum flexibility for your projects.
仕様
Parameter
Processor
XIAO nRF52840 Plus
ePaper Connector
FPC 24 Pin 0.5mm
FPC 50 Pin 0.5mm
Battery Connector
JST 2.0mm
Switch
Battery Power ON/OFF
Power Supply
- 3.7V Li-Battery
- USB Type-C
Button
-1x Reset button
-3x User button
ハードウェア概要
用途
  • Smart Name Badge: Create battery-powered ePaper name tags for events or offices, updated via NFC tap or wireless connection, with buttons to switch profiles or display QR codes.
  • Dynamic Price Tags: Build low-power retail labels that show prices, stock levels, or promotions on differernt size ePaper, updated periodically without needing constant power.
  • Meeting Room Signage: Use as status boards for meeting rooms, showing booking info, occupant name, or “Do Not Disturb” states, with buttons to quickly change modes.
  • Portable Checklist Board: Make handheld task boards or packing lists that keep their content even when powered off.
XIAO ePaper DIY Kit(nRF52840) - EN04
SKU E25120101
Powered by XIAO nRF52840 Plus, the display board EN04 supports both 24-pin and 50-pin ePaper displays. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital signage, electronic labels, and portable information boards.
JPY¥8849.00
XIAO ePaper Display Board(nRF52840) - EN04x1¥1726.00
7.3" spectra™ 6 E-Ink / ePaper Display with 800x480 Pixels, SPI interface, Support XIAO/Arduinox1¥7123.00
