必須オプションを選択してください
おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Recommended Bundles
Bundle
Core MCU & Base
Recommended Sensors & Display
Price
Ideal For
Pet Air Quality Kit
XIAO ESP32-C3
Grove Base for XIAO
Grove -Smart Air Quality Sensor-SGP41
Grove - Temperature & Humidity Sensor Pro (DHT22/AM2302)
$27.25
Cat Litter Box Monitoring – Detect odors and VOC buildup around litter boxes, monitor temperature and humidity, and trigger cleaning.
CO₂ Ventilation Kit
XIAO ESP32-C6
Grove Base for XIAO
Grove - CO2 & Temperature & Humidity Sensor(SCD41)
$70.55
Meeting Rooms & Bedrooms – Monitor CO₂ concentration and receive ventilation reminders when air becomes stale. Ideal for offices, study rooms, and sleep quality monitoring.
3D Printer Air Monitor Kit
XIAO ESP32-C6
XIAO ePaper Display Board(ESP32-S3) - EE05
Grove - SEN55 All-in-one environmental sensor
2.9" 4-Color ePaper Display
$80
3D Printing Rooms & Workshops – Monitor particulate matter and VOC emissions from PLA, PETG, ABS, ASA, and other materials. Trigger exhaust fans or air purifiers automatically during printing.
Air Pollution Monitoring Station
XIAO ESP32-C5
Seeed Studio Expansion Board Base for XIAO with Grove OLED
Grove - I2C Hub (6 Port)
SEN55+BME260+SCD41
$152.6
Indoor & Outdoor Environmental Monitoring – Measure PM1.0/2.5/4/10, VOC, NOx, CO₂, temperature, humidity, and barometric pressure.
1. 100% Solderless & Plug-and-Play: Zero-Barrier for Beginners
  • No Soldering Iron Required: Say goodbye to complex wiring diagrams, loose breadboard cables, and hot soldering tools.
  • The Power of Grove Ecosystem: Simply snap your XIAO dev boards onto the Expansion Base, and connect your chosen sensors using unified Grove cables. It’s as simple as building blocks—making it 100% foolproof for absolute beginners.
2. Full-Spectrum Air Monitoring: From Starter to Professional
Whether you need basic bedroom monitoring or high-precision industrial data, this kit covers all price points and accuracy levels.
  • Comprehensive Detection: Monitor Temperature, Humidity, Barometric Pressure, CO2, VOCs, NOx, and PM1.0/2.5/4/10 esc. with premium, modular sensors.
  • Flexible Component Selection: Mix and match sensors to fit your budget and tracking needs—from entry-level to high-end modules like the BME688 or SEN55. Add a sleek ePaper screen or OLED screen for visual data, or keep it screen-free. You only buy what you need.
3.100% Local Control via ESPHome & Home Assistant
  • Native ESPHome Integration: Every single sensor and display in this kit is officially supported by ESPHome.
  • Effless YAML Configuration: Thanks to ESPHome's latest updates, writing and deploying YAML configurations has never been faster or smoother.
  • Privacy-First Smart Home: Zero reliance on external cloud servers, zero subscription fees. All environmental data stays 100% local, pushing instant updates directly to your Home Assistant dashboard for advanced automations.
用途
  1. Smart Ventilation & Climate Control
  2. HVAC & Air Purifier Automation
  3. Custom Notifications & Dashboard Alerts
  4. Historical Air Quality Tracking
⚠️ Important Reminder: This kit provides the hardware and raw sensor data via ESPHome. It does not control external appliances out of the box. All smart rules, device pairings, and automation logic must be set up and configured by the user inside Home Assistant.
You do not need to write C++ or Arduino code. However, you will need to upload a YAML configuration file via ESPHome to flash the device. Don't worry—every component in this kit is natively supported by ESPHome.
No. This kit is a data collector (sensor), not a direct controller. It measures air quality and sends that data to your Home Assistant server. To control external appliances, you must already have smart appliances (or smart plugs) integrated into your Home Assistant, and you must configure the automation rules inside Home Assistant yourself.
No, displays are completely optional. The kit can run perfectly as a "headless" (screen-free) background sensor that silently reports data to your Home Assistant dashboard. You can choose to add an OLED or ePaper display during purchase if you want immediate, on-device visual readings, or skip it entirely to save budget.
While the kit is optimized for Home Assistant via the ESPHome native API, you can technically use it with any platform that supports MQTT or Web Servers (which can be enabled in the ESPHome YAML configuration). However, for the best and easiest experience, we highly recommend using it within the Home Assistant ecosystem.
Air Quality Monitor ESPHome DIY Kit for Home Assistant - Solderless, Local, Custom
SKU E26060401
Build your ultimate local-first environmental tracker with the Air Quality Monitor ESPHome DIY Kit for Home Assistant. Designed for absolute beginners and smart home experts alike, this 100% solderless, modular kit lets you plug, play, and customize in minutes. Simply select your powerhouse MCU from the XIAO ESP32 series, snap it onto a Expansion Base, and effortlessly chain premium Grove sensors. With the unified Grove ecosystem, you can monitor PM2.5, CO2, and VOCs instantly via simple cables, with zero wiring confusion or soldering required. Enjoy seamless Home Assistant integration, 100% privacy, and total local control in minutes!
Home Assistant Starter KitHuman Detecting ESPHome DIY Kit
USD$0.00
オプションを1つ以上選択してください
product.detail.alsoAdd.title
