The Grove-SEN55 is a comprehensive solution for measuring essential air quality parameters including particulate matter, VOC, NOx, humidity, and temperature. Its advanced algorithms make integration into HVAC and Air Purifier systems effortless and providing a hassle-free experience for end-users without the need for any coding.
| Parameter | Conditions | Value | Units |
| Sampling interval | - | 1±0.03 | s |
| Lifetime | 24 h/day operation | > 10 | years |
| Acoustic emission level | 0.2m | 24 | dB(A) |
| Long term acoustic emission level drift | 0.2m | +0.5 | dB(A) / year |
| Mass concentration specified range | 0 to 1'000 | μg/m3 | |
| Mass concentration size range | PM1.0 | 0.3 to 1.0 | μg |
| PM2.5 | 0.3 to 2.5 | μg | |
| PM4 | 0.3 to 4.0 | μg | |
| PM10 | 0.3 to 10.0 | μg |
| Compensated outputs | - | Temperature and Relative Humidity | °C %RH |
| Typical accuracy temperature | @ 15-30 °C, 50 %RH | ± 0.45 | °C |
| Max. accuracy temperature | @ 15-30 °C, 50 %RH | ± 0.7 | °C |
| Repeatability temperature | @ 25 °C, 50 %RH, τ 63% | < 60 | s |
| Parameter | Comments | Values | Units | ||
| Min | Type | Max | |||
| Output signals | VOC Index | 1 | - | 500 | VOC Index points |
| NOx Index | 1 | - | 500 | NOx Index points | |
| Device-to-device variation | VOC Index | <±15 | VOC Index points | ||
| NOx Index | <±25 | NOx Index points | |||
| Repeatability | VOC Index | <±5 | VOC Index points | ||
| NOx Index | <±10 | NOx Index points | |||
| Grove - all in one environmental sensor SEN55 | x1 |
| Grove cable | x1 |
The Grove-SEN55 is a comprehensive solution for measuring essential air quality parameters including NOx, VOC, particulate matter, humidity, and temperature. Its advanced algorithms make integration into HVAC and Air Purifier systems effortless and providing a hassle-free experience for end-users without the need for any coding.
