おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes motor, driver circuitry, planetary reducer, and dual magnetic encoders in a lightweight 310g design
  • Simplified Wiring Features a "One-in-One-out" wiring design, enabling easy daisy-chain connections for complex robot joints
  • Dual Encoder Features 14-bit absolute magnetic encoders for high-precision position control
  • Wide Voltage Compatibility Supports 24-60V input range (Rated 48V), optimized for modern battery-powered robots
  • High Torque Density Delivers 14 N.m peak torque with a 10:1 reduction ratio using machined steel gears
仕様
Product
RobStride 00 Motor
Voltage Range
24-60V
Operating Temperature
-20℃~50℃
Mechanical Dimension
57mm x 57mm x 51mm
Communication Interface
CAN
Gear Ratio
1:10
Rated Output Power
136W (Calculated based on Rated Load 5N.m @ 260rpm)
Rated Torque
5 Nm
Peak Torque
14 Nm
Pole pair
14
ハードウェア概要
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501310099
COOCHINA
部品リスト
RobStride 00 Motor
x1
XT30(2+2) Cable
x1
RobStride 00 QDD 14N.m integrated actuator module
SKU 100083284
RobStride 00 is a highly-integrated QDD actuator module that includes a motor, driver circuitry, planetary reducer, and dual magnetic encoders. The module has a 10:1 gear ratio, with 14 N.m peak torque and weighs only 310g. The module is perfect for robotics applications such as quadruped robots, humanoids, and robot arms. It can be controlled through a 1Mbps CAN interface
USD$125.00
product.detail.alsoAdd.title
