おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated: Features a four-in-one design integrating driver, motor, planetary reducer, and dual magnetic encoders in a lightweight 880g package.
  • High Torque Density: Delivers 60 N.m peak torque with a 9:1 reduction ratio, achieving a torque density of 66.67 N.m/kg.
  • Dual Encoder: Equipped with dual magnetic encoders for high-precision position feedback.
  • Wide Voltage Compatibility: Supports 15-60V input range (Rated 48V), optimized for modern battery-powered robots.
  • Convenient Development: Comes with comprehensive debugging software, modules, and sample programs for easy development.
  • Versatile Applications: Suitable for robotics, consumer products, and automation control applications.
仕様
Item
Product
RobStride 03 Motor
Voltage Range
15-60V (Rated 48V)
Operating Temperature
-20℃~50℃
Operating Humidity
5%~85%
Storage Temperature
-30℃~70℃
Mechanical Dimension
106mm x 106mm x 56mm
Communication Interface
CAN
Gear Ratio
9:1
Rated Output Power
380W ± 10%
Rated Torque
20 Nm
Peak Torque
60 Nm
Poles
42
Phases
3
Driver Method
FOC
Encoder
Magnetic Encoder x 2
Weight
880g ± 20g
Protection Level
IP52 (Supporting customize IP67)
Terminal Interface
XT30 + GH1.25
ハードウェア概要
ドキュメント
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
RobStride 03 Motor
x1
XT30 + GH1.25 Cable
x1
RobStride 03 QDD 60N.m integrated actuator module
SKU 100081690
RobStride 03 is a high-performance QDD actuator module that features a four-in-one design integrating driver, motor, planetary reducer, and dual magnetic encoders in a lightweight 880g package. The module has a 9:1 gear ratio, with 60 N.m peak torque and a torque density of 66.67 N.m/kg. With comprehensive debugging software and sample programs, it is perfect for robotics applications such as quadruped robots, humanoids, robot arms, AMRs, and AGVs. It can also be used in consumer products like electric vehicles, scooters, e-bikes, exoskeleton joints, and lawn mowing robots.
USD$225.00
product.detail.alsoAdd.title
