おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes motor, driver circuitry, planetary reducer, and dual magnetic encoders in a compact 405g four-in-one design
  • Reliable Connection Equipped with XT30PB electrical terminals ensuring stable high-current power and signal transmission
  • Dual Encoder Features 14-bit dual magnetic encoders for high-precision feedback and control
  • Wide Voltage Compatibility Supports 24-60V input range, perfectly optimized for 48V battery-powered robotic systems
  • High Torque Density Delivers 17 N.m peak torque with a 7.75:1 reduction ratio, ideal for high-performance quadruped and humanoid robots
仕様
Product
Hightorque HTDW-5047-20 Motor
Voltage Range
24-60V
Operating Temperature
-20℃~50℃
Mechanical Dimension
78.5mm x 78.5mm x 45.5mm
Communication Interface
CAN (1Mbps)
Gear Ratio
1:7.75
Rated Output Power
170 W
Rated Torque
6 Nm
Peak Torque
17 Nm
Pole pair
14
ハードウェア概要
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
RobStride 02 Motor
x1
XT30(2+2) Cable
x1
RobStride 02 QDD 17N.m integrated actuator module (Dual Encoders)
SKU 100064875
RobStride 02 is a highly-integrated QDD actuator module that includes a motor, driver circuitry, planetary reducer, and dual magnetic encoders. The module has a 7.75:1 gear ratio, with 17 N.m peak torque and weighs only 405g. The module is perfect for robotics applications such as quadruped robots, humanoids, and exoskeletons. It can be controlled through a 1Mbps communication interface
USD$145.00
product.detail.alsoAdd.title
