おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes motor, driver circuitry, planetary reducer, and dual magnetic encoders in an ultra-lightweight 191g design (3-in-1)
  • Compact Design Dimensions of only 46x46x44mm with single port wiring, ideal for space-constrained joints
  • Dual Encoder Features 14-bit absolute magnetic encoders for precise position feedback
  • Wide Voltage Compatibility Supports 15-60V input range, compatible with various battery systems (Rated 48V)
  • Efficient Performance Delivers 5.5 N.m peak torque with a 7.75:1 reduction ratio and closed-loop temperature control
仕様
Product
RobStride 05 Motor
Voltage Range
15-60V
Operating Temperature
-20℃~50℃
Mechanical Dimension
46mm x 46mm x 44mm
Communication Interface
CAN
Gear Ratio
1:7.75
Rated Output Power
17 W (Calculated based on Rated Load 1.6N.m @ 100rpm)
Rated Torque
1.6Nm
Peak Torque
5.5 Nm
Pole pair
10
ハードウェア概要
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
RobStride 05 Motor
x1
XT30(2+2) Cable
x1
RobStride 05 QDD 5.5N.m integrated actuator module
SKU 100035437
RobStride 05 is a highly-integrated QDD actuator module that includes a motor, driver circuitry, planetary reducer, and dual magnetic encoders. The module has a 7.75:1 gear ratio, with 5.5 N.m peak torque and weighs only 191g. The module is perfect for robotics applications such as joints for small quadruped robots and robotic arms. It can be controlled through a 1Mbps CAN interface.
USD$110.00
product.detail.alsoAdd.title
