おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes motor, driver circuitry, planetary reducer, and dual magnetic encoders in a compact 3-in-1 design
  • Education Focused Specifically optimized for developers and educational users, offering a cost-effective solution ($80) for robotic learning
  • Dual Encoder Features 14-bit dual magnetic encoders for precise position recognition and control
  • Wide Voltage Compatibility Supports 15-60V input range (Rated 48V), adaptable to various power supply systems
  • High Torque Output Delivers 6 N.m peak torque with a 9:1 reduction ratio using powder metallurgy gears
仕様
Product
RobStride EduLite 05 Motor
Voltage Range
15-60V
Operating Temperature
-20℃~50℃
Mechanical Dimension
46mm x 46mm x 44mm
Communication Interface
CAN
Gear Ratio
1:9
Rated Output Power
19 W
Rated Torque
1.8 Nm
Peak Torque
6 Nm
Pole pair
10
ハードウェア概要
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
x1
XT30(2+2) Cable
x1
RobStride EduLite 05 QDD 6N.m integrated actuator module
SKU 100060739
RobStride EduLite 05 is a highly-integrated QDD actuator module that includes a motor, driver circuitry, planetary reducer, and dual magnetic encoders. The module has a 9:1 gear ratio, with 6 N.m peak torque and weighs 242g. The module is explicitly recommended for developers and educational robotics applications. It can be controlled through a CAN interface
USD$80.00
product.detail.alsoAdd.title
