おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly Integrated Design
Combines motor, driver electronics, planetary gearbox, and encoder into a compact actuator weighing only 380g.
  • High Torque Density
Delivers 17 N.m peak torque with 44.73 N.m/Kg torque density, enabling powerful actuation in compact robotic systems.
  • Efficient Planetary Gear System
Utilizes a 7.75:1 machined planetary reduction gear to provide stable and smooth torque output.
  • Precision Magnetic Encoder
Integrated 14-bit absolute magnetic encoder provides high-precision position feedback.
  • Wide Voltage Compatibility
Supports 24–48V operating voltage with 36V rated voltage, ideal for battery-powered robots.
  • CAN Bus Communication
Supports 1 Mbps CAN communication for reliable control in multi-joint robotic systems.
仕様
Item
Product
RobStride 01 Motor
Voltage Range
24-48V (Rated 36V)
Operating Temperature
-20℃ ~ 50℃
Mechanical Dimension
78.5mm × 78.5mm × 40mm
Communication Interface
CAN (1 Mbps)
Gear Ratio
1:7.75
Rated Output Power
170W ± 10%
Rated Torque
6 Nm
Peak Torque
17 Nm
Poles
28
Phases
3
Driver Method
FOC
Weight
380g ± 3g
Encoder
14-bit Absolute Magnetic Encoder x 1
Protection Level
IP52 (Customizable to IP67)
Terminal Interface
XT30PB
ハードウェア概要
ドキュメント
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
RobStride 01 Motor
x1
XT30(2+2) Cable
x1
RobStride 01 QDD 17N.m integrated actuator module
SKU 100029452
RobStride 01 is a compact and highly integrated QDD actuator module that integrates a motor, driver circuitry, planetary reducer, and magnetic encoder into a single lightweight unit. The module features a 7.75:1 reduction ratio, delivers 17 N.m peak torque, and weighs only 380g, achieving outstanding torque density.
RobStride 01 is ideal for robotics applications such as quadruped robots, humanoid robots, robotic arms, and mobile robots. The module supports FOC control and can be easily controlled via a 1 Mbps CAN communication interface, enabling precise and responsive motion control.
USD$130.00
product.detail.alsoAdd.title
