おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly-integrated Includes motor, driver circuitry, planetary reducer, and dual magnetic encoders in a powerful 621g module
  • Simple Connection Features "One-in-One-out" wiring design, enabling efficient daisy-chain connections for complex multi-joint robots
  • Dual Encoder Features 14-bit single-turn absolute magnetic encoders for precise motion control
  • Wide Voltage Compatibility Supports 15-60V input range (Rated 48V), compatible with various high-power battery systems
  • Extreme Torque Density Delivers 36 N.m peak torque with a 9:1 reduction ratio, designed for heavy-duty robotic joints
仕様
Product
RobStride 06 Motor
Voltage Range
15-60V
Operating Temperature
-20℃~50℃
Mechanical Dimension
88mm x 88mm x 49mm
Communication Interface
CAN
Gear Ratio
1:9
Rated Output Power
115 W (Calculated based on Rated Load 11N.m @ 100rpm)
Rated Torque
11 Nm
Peak Torque
36 Nm
Pole pair
14
ハードウェア概要
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
RobStride 06 Motor
x1
XT30(2+2) Cable
x1
RobStride 06 QDD 36 N.m integrated actuator module
SKU 100010715
RobStride 06 is a highly-integrated QDD actuator module that includes a motor, driver circuitry, planetary reducer, and dual magnetic encoders. The module has a 9:1 gear ratio, with an impressive 36 N.m peak torque and weighs 621g. The module is perfect for high-load robotics applications such as large quadruped robots, humanoids, and exoskeletons. It can be controlled through a 1Mbps CAN interface.
USD$210.00
product.detail.alsoAdd.title
